pritish
Hi All,
I am hoping that someone can help me. I live in Michigan so the weather gets below freezing regularly - that is when my charging problems start. I have a Charge Station Pro that is on a 30amp circuit and is hardware limited to 24 amps. Whenever the temperature drops below 30 degrees and I put the truck to charge, invariably, after few minutes, the message pops up "Vehicle Charging Error". I have taken it to the dealer and the dealer says that there are no issues with the truck but whether I use the mobile charger or charge station pro at home, the both display the Vehicle Charging Error.
If the temperature is between 30 degrees and 45 degrees, then I have to take the truck for a one mile spin before putting the truck on the charger. If I do not do that, again the message pops up.
I have opened a ticket with Ford but they say nothing is wrong. I went to the dealer and they say that because I have limited the charger to 24 amps, that is causing the issue.
I feel like the battery needs to get pre-conditioned to accept the charge but for whatever reason, it is not getting preconditioned.
Has anybody else faced similar issue with charging the truck at home?
