Customizing all profile photos
bartlee
Bart
2022 F-150 Lightning Lariat
Designer
As I was working on getting my custom profile image to show up, I found I could customize all the other profiles as well. Here are the steps (I’m on iOS):
- Make sure the phone number tied to your Ford account only shows up on your contact entry. Add the profile photo you want to use to your contact entry.
- In your Lightning, go to Settings > Phone List, select your phone and hit Manage Contacts. Tap ‘Re-Download Contacts’
- Give it a few minutes, and then check your contact entry to see if your new image shows up. If so, edit your profile and hit Change Contact Photo. Your new photo should be the first option. Sometimes I had to wait a little longer for it to show up.
- If you want to do this for the other profiles, assign THEIR photo to YOUR entry on your phone and re-download your contacts. Then you should be able to assign it to your profile and then go do their profile. Repeat this process for each profile, and then go back and do yours last.
It’s a bit of a pain, but this worked for me. I don’t have PAAK assigned for the other profiles, so I haven’t tested if you can just use their contact photos in that case without having to go through this process.
Ford F-150 Lightning Customizing all profile photos EDD8DA83-0075-41D4-A489-B6AC02508235
duncanmclain
Duncan
St. Louis, MO
F150 Lariat ER
Supreme Galactic Commander
That's pretty cool, Looking forward to messing around with that
Got mine to work too, but I needed to turn on "Profile picture sharing" on my phone before it would post to the truck contacts.
Ford F-150 Lightning Customizing all profile photos 1673279531022
Reloaded the contact list, then edited my profile. Note I switched from android auto to direct bluetooth phone connection to see the options menu for picking an avatar photo.
Ford F-150 Lightning Customizing all profile photos 1673279721246
Thanks for the info - I've got my photo updated on the profile for the first time since having the truck in 6 months. I've been through all of this a few times, but I think the key is that I found a duplicate entry for my name/number that I didn't know was in the phone. I had an entry from my work Outlook profile. Thanks for that info.
I'm guessing the duplicate number is what was keeping mine from updating although I would have never suspected this since you have to enter your name on the profile, I suspected they were keying off the name.
bartlee
bartlee
Bart
Designer
I saw it mentioned on the Mach E forum. Didn’t verify myself, but it looked like several people had the same issue.
Reactions: GDN
Jer
Jer
Oklahoma
‘23 Lightning Lariat,‘21 Bronco, ‘17 F350, ‘76 K20
Nice instructions, worked well
Bump
Reactions: GDN
No Oil HaHa
Josh
2022 Ford F150 Lightning Lariat ER
I can’t get this to work. I keep getting a “Process interrupted. Please try again. Avoid using vehicle until the process completes.”
Will it take a couple of minutes for the picture to appear under the profile photo section?
For reference: I do not have multiple contacts in my phone, my phone number matches what is in the FordPass app, under the contact listings I can get my profile photo to appear under both my contact setting and the “my number setting.”
bartlee
bartlee
Bart
Designer
It's been two and a half years since I did this so my memory is a little hazy, but I don't think it took several minutes for the picture to show up. I never got that Process Interrupted dialog.
jredondox
Jorge
San Diego, CA
2021 F150
I had this working on my 22 but my 2025 I cant get the damn picture to show up. did it stop working?
The Weatherman
South Central KY
Yep. The 22’s won’t change them now. Ask me how I know. \|/
  • Sad
Reactions: GDN
No Oil HaHa
Josh
Yeah, I gave up on this…:explode:
