Day one Lightning owner climate/app/locking questions
dww
San Antonio, TX
F150L, Tesla 3P, YP
No, that's not it. I suggest watching a video on what BlueCruise is.
Also, BlueCruise is looking for lines on either side of the lane. If either side has no lines, you will see the hands-free mode immediately turn off.
My screens aren’t exactly like that. The car can go from blue wheel, to normal, to red warning back to blue wheel all in the same BC session on a lane marked highway. It does not change lanes with the blinker so I assume I have 1.1, some trucks have 1.2 and lane change on signal. How do I check my version number?
Ford F-150 Lightning Day one Lightning owner climate/app/locking questions IMG_3416
Ford F-150 Lightning Day one Lightning owner climate/app/locking questions IMG_3417
Ford F-150 Lightning Day one Lightning owner climate/app/locking questions IMG_3418
Ford F-150 Lightning Day one Lightning owner climate/app/locking questions IMG_3419
Ford F-150 Lightning Day one Lightning owner climate/app/locking questions IMG_3420
Most of your pictures aren't showing anything.
You have to be on a DIVIDED HIGHWAY. Here is a map link so you can find out if your road is BC enabled. https://www.ford.com/technology/bluecruise/
If it's not hands-free, you have to have your hands on the steering wheel.
Edit - now I see the handsfree symbol. That will go away when you approach a curve where it can't navigate at speed, when the lines go away, when you exceed 80mph. That's how it's designed to work.
When it upgrades to 1.3 next year, it will work better.
dww
San Antonio, TX
F150L, Tesla 3P, YP
They should show now. They were duplicating and I had to go back and edit. I’m on IH 10 in San Antonio.
dww
San Antonio, TX
F150L, Tesla 3P, YP
When the blue wheel is away is the resistance significantly reduced? Does the blue wheel go away when I hit the turn signal or was that coincidence?
It turns off the instant you activate the blinker, yes. 1.3 will stay on.
I don't think you're really understanding the features.
There are two modes of BlueCruise, hands on and hands free. The blue wheel clearly shows you the words "Hands Free", meaning it is steering, not you. Therefore, you shouldn't be testing the resistance, because you should be letting go of the wheel. Yes, if you try to steer there is resistance, but you can steer.
In hands on mode, it will keep the vehicle between the lines. If you steer over the line, it will warn you. There are various settings that you should look at under headings like Lane Centering. You can make it steer back, you can make it warn harder. There is also a gap setting for vehicles in front of you.
You will also find that even in local driving, it will keep you in the lane. If you stray onto the line, it's going to warn you.
Much of this is explained in the manual, on the center screen. It's also in FordPass, and downloadable in PDF format from owner.ford.com
dww
San Antonio, TX
F150L, Tesla 3P, YP
This is the mode I am finding the most confusing. It switched to this mode on it’s own (when there is curve or the lines are not as good) and it’s steering “ability” seems not to have changed, but the resistance feels less and it will go back to hands free without my input.
For comparison Tesla autopilot is either off or on. There is no helping it or directing it with the wheel and it won’t change to TACC and then back to AP. I’m not asking BC to be the same just understand the different logic and rules.
Thank you for helping me out!
Yes, it will go from hands free to hands on as you approach a curve, then switch back to hands free after the curve.
1.3 will remove some of that, and slow for the curve (or so people say), and then you can gently apply accelerator to go faster if you want.
Log into Ford.com, scroll down, and you should see links when you click to a page like this - https://www.ford.com/support/category/sync-and-technology/co-pilot-360/
dww
San Antonio, TX
F150L, Tesla 3P, YP
A few more:
1. Does the AC recirc turn off at the end of every drive? Can that not be set to default recirc on?
2. Pro power. Does the truck have to be fully on? Is there a mode that turns off all the other stuff so you don’t accidentally leave the heat and all the seat warmers on?
3. Do you leave the auto present on? I always have my phone on me so every time I walk by the truck I get the light and step board show even when I’m 25 ft away.
4. Is there a save button that I am missing? I have changed the automatic updates to ON three different times with the schedule as any day at 1:00 am. Every time I check back it set to Off.
Surfnturf
Hawaii
Lightning
1. No dog mode. No way to get that information from the app. Only way to keep temp is to have the truck running. You would have to deactivate the power down timer and lock the door with the truck running.
How do you deactivate the power down timer? My truck will always shut down after 15 mins being parked.
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
Your posts on this thread have been so helpful as I've had my truck for 3 days and am learning all about it.
Thank you for taking the time to answer the questions that have been posed.
TheWoo
Manhattan, KS
A few more:
1. Yes, it turns off. It will also turn off automatically while driving if it senses the moisture content getting too high to prevent fogging.
2. Truck has to be on. It's one of the more annoying lack of features, imo, that there's no way to turn on Pro Power without turning everything on. Would love for Ford to add a "camp mode" or the like.
3. I have mine on. Others off. User case.
4. This should stay on. Weird.
dww
San Antonio, TX
F150L, Tesla 3P, YP
1. This is the most annoying “feature”. The cab is constantly getting filled with exhaust fumes no matter what the climate setting. I thought I had tricked it by setting the set-point way below the outside so it would not try to let in outside air because it would have to heat that air, but it eventually did.
4. I did a reset (hold down L&R search buttons) and I think that fixed it. It is saved now.
Set it on vent instead of auto, then turn on recirc...
