"Electrical System Drain - Service Requested" error message
Stang68
NJ
Mach E GT Performance, Lightning Lariat Extended
What info did you have to give the utility in order to participate in the program? Do they access the EVSE or the car?
They have access to the EVSE. I was provided a "connection code" to input into the Chargepoint app, as seen below. It then populated the charging plan and activated, all in the Chargepoint app:
Ford F-150 Lightning "Electrical System Drain - Service Requested" error message unnamed (2)
In that case, I suspect your idea to allow the EVSE to control the schedule will solve your problem.
