F150 Lightning FORscan thread
jimfigler
Orchard park, NY
Could you verify that your 724-02-01 line is correct? I pulled up the spreadsheet and that isn't an option. One option is xxxx-x*xx and the other is xxxx-xx**. Thank you!
If you figured that out, please post it. Thanks.
BennyTheBeaver
2023 Lightning XLT ER
slaftos
North Carolina
2023 Lightning Lariat ER Antimatter Blue
does anyone have pids for monitoring lightning motor temps, HV batt temps, HV charge/discharge rates?
BennyTheBeaver
Would be great if you guys can also figure out zone lighting.
I recently looked at a Order guide/equipment chart. Zone Lighting may only be a MY23 thing (on Pro).
BennyTheBeaver
So you think 23 Pro might have some additional hardware to make it work?
Just a hypothesis based on the most recent order guide.
jimfigler
Orchard park, NY
Will do, @Blochead21 and I are trying to figure it out. I got the menu to show up but the wipers stay on with no water.
I’m still waiting on the sensor. I did see rain sensor in each of those modules when you look in the menu based section (not as built) not sure if that will help you
Blochead21
PA
Black 22 XLT 311pkg
Mine was 724-02-01 xxxx-xC4x- —
I got my sensor and changed the value to the above. Haven’t been able to test with rain or water.
Priccijr
Pete
RI - USA
2022 F150 Lariat Iced Blue
I will double check mine tomorrow. We had a light rain here last week and the wipers worked. It hasn’t rain since the stalk is still on the single rain drop with no wiping.
BennyTheBeaver
My rain sensor works with the values as posted here.
A word of caution to those using Forscan with our trucks. Reset each module after you make a change to it. My rain sensor wasn't working and I couldn't figure out why. I had to pull my 12v last night to remedy FordPass issues and today my sensor worked with no issues. I realized cycling the ignition (as recommended by Forscan) isn't enough. There is a reset function for each module in Forscan that you can click after you have written the new values.
Priccijr
Pete
RI - USA
Sorry you had such troubles BENNY.
jimfigler
Orchard park, NY
did you use xC4x? My sensor arrived today, going to try after work.
