Is there any benefit to disabling the startup animation? Could you link me to the location in this thread where the config is located?Want to thank all those to walked the path before me. Just did anti-glare and disable startup boot animation on the 15" screen. Swivel still works great as well.
https://www.f150lightningforum.com/...ngs-chimes-honks-bings-bongs-and-dongs.18175/Is there any benefit to disabling the startup animation? Could you link me to the location in this thread where the config is located?
Thanks! Didn't realize it was a separate thread.https://www.f150lightningforum.com/...ngs-chimes-honks-bings-bongs-and-dongs.18175/
It boots into the main UI (AA in my case) faster and don't need to be hit with the long animation. Also tried to disable the triple chime on start up but the change didn't take, may need to try it again later.
Getting rid of the chimes has been a wonderful change. Between the normal chimes and some errors during my comma 3x boot up it was a 30 second artillery strike of bings bongs and beeps.https://www.f150lightningforum.com/...ngs-chimes-honks-bings-bongs-and-dongs.18175/
Is the module in the linked thread the correct one? I have a '24 Lariat so I'm not sure if something changed for the 2024s. I did pull the module last night and the change was written. I'll have to check again during my lunch break because those dings at the beginning are really annoying.Getting rid of the chimes has been a wonderful change. Between the normal chimes and some errors during my comma 3x boot up it was a 30 second artillery strike of bings bongs and beeps.
