Ford APP-cannot change preferred charge times-wrong percent and range showing
akgreg
Kenai, AK
2022 F350 SD, 2023 Lariat ER
Builder
I just got home and need to charge truck. My preferred times to charge are between 12-5am. I tried to change this on the app and it will not save. It just shows the old preferred times. I then also noticed that on the app home screen it show my range at 77% and 218 miles. The truck shows 20% and 42 miles. I was able to delete my preferred times in the truck by deleting my locations. Truck is now charging. The app does not reflect this. It still shows my preferred times. It also shows my truck being parked at a different location from 6 days ago. WTF?
I then looked at my other truck (F-350) on the app and it showed that it was ON. Well that is impossible as it is in my hangar and I have the keys in my hand. WTFx2
My first thought is to just delete the app and start over but wanted to get some input from others before I do anything.
Thanks in advance
Everyone is reporting FordPass issues, and most are doing the wrong thing, like you did, which is to try and fix something that you can't fix. Too late now, but I would have recommended you do nothing.
akgreg
akgreg
Kenai, AK
Builder
Recommend do nothing? I need my truck to charge so I can drive it. What is it specifically that I did wrong in order to get my truck to charge? Trying to learn here.
You're trying to fix a broken app. You can't. Uninstall, reinstall, tweak settings, it's a FORD issue that you can't fix.
Go in truck, initiate charging, that's all you can do. The rest is make work for you.
akgreg
akgreg
Kenai, AK
Builder
I guess I have been lucky to this point. Had my Lightning 1 year now and never an issue with app.
Ford servers were glitchy this morning, did not follow my departure schedule at 0650, but at least I could initiate the remote start.
You think this is bad, Mercedes MBRACE system has been on the fritz for 5 days, 2017 and older vehicles can't use any remote functions.
UPDATE: Benz issued an updated MBRACE app 4.5.15 to restore broken functionality on 2/25
RyZac
Owen
2023 ER Lariat w/Max Tow
Patiently waiting for them to fix. No longer see charging stats in the app. Cannot stop charging or change charge levels. All worked up to about a month ago.
Fix what?
Servers are working fine most of this week, could be issues with communications from your truck that are the cause. Try a 12v reset at the LVB, make sure you don't have any updates installing before the disconnection of the negative terminal.
RyZac
Owen
I've gotten the last two updates just fine in the last couple weeks. (10.1.1 & ECG-24.2.5.7)
I can remote start, lock just fine.
update: Twice today it started showing charging stats like before. Worked this AM for a couple hours then it stopped. As I started writing this post it's back to working. Must be a Ford Gremlin 🫨
