Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes
Not much to see.
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1736375955914-qi
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1736375979478-j0
Lightning Bronson
Jansen
Greater Toronto Area
F150 Lightning Lariat
Snow Removal, Landscaping
iOS users: Gets widgets back again
Android: You get nothing! You lose. Good day, Sir!
(I don't understand why we can't get widgets either, with more functionality)
I'm enjoying the Watch4 integration.
I've noticed a few actions or the confirmation of actions taking very long time or not showing completed.
First example is the lock request, spins for an unusually long time, the green check doesn't appear.
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1736512637240-tw
Second example, I was trying to delete a [Departure Time] event from the task list, after clicking the delete button, the process did not complete and went back to displaying the event, I tried force/stop and cache clear, restart app, task still listed. The only way I could delete it was to try switching it off/on, then later the delete would work.
Is anyone else seeing similar?
On second attempt with locking, it took 20 seconds and eventually showed the lock request completed green check icon.
Probably more database congestion.
I can't change the settings.
Same, from my android version 5.10.0 of Ford Pass.
I've sent in a bug report via email and Playstore one star review with comments, y'all can do the same to make this a priority escalation & fix.
@Ford Motor Company
tls
New York
2022 Lightning
Glad to report that plug & charge is still active even though it's showing switched off without a switch to flip it back on, looking forward to FordPass 5.10.1 or 5.11.0 with this issue resolved.
Details here https://www.f150lightningforum.com/...ate-10-1-0-its-karaoke-time.21411/post-464586
I am getting messages in the notifications screen of the app that Plug&Charge has been activated even though I switched it off and want it off for reliable use of my Tesla and EA discount plans. Meanwhile we need to turn it back ON on the Mach E so an older relative who needs the convenience doesn't have to learn how to use multiple charging apps - but we can't. Who knows what state it's actually in on the truck or the car. @Ford Motor Company I appreciate that it was complaints very much like this about the app that led one of your reps to summarily hang up the phone on me two years ago and you to never respond again to any of my inquiries but I hope at least you're keeping track of how many customers are deeply dissatisfied with FordPass - in other words, basically all of us.
My phone updated last night. Now my PAAK doesn't work. The December security update didn't break it, but this did.
What version of android are you running & what hardware?
Ford Pass minor update 5.10.1 is out for Android, it now allows you to control Plug & Charge and sharing, you may need to try twice to make the change stick.
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1737474788156-lt
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1737474806190-sh
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1737474832336-ik
Ford F-150 Lightning Ford Pass 5.10.0 / 5.10.1 -Android Performance & bug fixes 1737474851488-uo
Mashedtators
2023 F150 Lightning
I had no problem deleting a departure time on iOS this morning
tls
New York
2022 Lightning
I mean, I can't even...how can their release process for an application that really has such a small number of user-exposed controls be such that 5.10 goes out with two of them completely disabled, and then 5.10.1 ships with them working kind-of-sometimes-if-you-try-repeatedly? Do they have no test coverage, or no accountability for whoever decides to ship it with tests failing, or...?
Wildneg
Kevin
2024 FORD LIGHTNING FLASH
Solution Architect
So mine updated 6 days ago (not sure what version). I noticed this morning when I was trying to activate a charge point charger through the public charging.... It wouldn't let me click anything once I find the charger.
I have never had this problem. Thinking the last update did this (the 6 days ago).
I checked and I have that 5.10.1 available.... Has anyone seen this issue and would the new version fix? Kind of worried to upgrade in case it causes other issues. I also noticed last night when I slid the 90 percent bar to 100 so it would charge fully for todays commute to work ... It did some weird message about going to 100 for departure? Usually it asks me if this is a one time thing... I say would say yes.
I woke up middle of the night and tried again and worked like it usually does.
I would suggest installing 5.10.1, it's definitely a bug fix release, as to whether it's addressing your observation I have no idea, (scant release notes).
