Ford Pass stopped updating
BennyTheBeaver
2023 Lightning XLT ER
Within the last 9 days, I had this happened 4 times, and had to disconnect the 12V negative every single time. This is really frustrating!
The dealer doesn't even have a clue, this forum contains a lot more information, unfortunately...
Yeah, again blame @Ford Motor Company .
Their lack of communication and transparency with the dealers is frankly embarrassing. Alot of people have come to these forums searching for information because this community is more informed than the dealers.
Until Ford guts upper management and actually tries to change their processes these things will continue.
Fantastic truck, horrendous customer support.
Ford Motor Company
Official Ford Account
Ford
F-150
Just spoke to Ford and they have confirmed that it was the latest update that messed stuff up. They dont have a fix for now and tell you just to wait for the next update scheduled sometime in February.
Good morning! If you'd like some assistance with your update concerns, feel free to send over a private message with your VIN and dealership info. I can look into things on my end.
Greenhme
Jorge
2023 F-150
I just disconnected the negative wire on the 12V Battery and can confirm that it does fix the issue. For how long time will tell. One note that I did notice is the radio station memory is gone.
stickyfingers
Sam
Toronto
F150ROD
U.S. Navy Retired
My Ford Pass started working on its own. I just stopped paying attention to it. For me it’s too much of a hassle to disconnect the 12v have to put in my presets again. I’d rather take my key fob and call it a day. Eventually @Ford Motor Company will fix it
Eastbaylightning
Antz Tony
Walnut Creek, California
F150 Lightning Pro
When I left the truck yesterday at the dealer, Ford Pass was not updating. I think the dealer disconnected the 12V and it worked exactly when I tried to pick it up in the afternoon.
Last night it stopped working again and it's been 16 hours, not updating. I believe this is the 5th time in 8 days.
I will PM @Ford Motor Company and see if they can check this issue.
This is what the dealer put in the report:
"Checked PTS website and found the connected vehicle history updates every day. The problem is not with the vehicle. The vehicle is sending out the information to the Ford website. Checked for codes. No related codes found. Checked Oasis and no TSB's or special service messages found. Checked for software updates. None found. Recommend the customer check his phone to make sure it's fully updated and the Fordpass app is fully updated. No problem found at this time."
:unsure:
Canadian Lightning
Vancouver BC
2022 Lightning Anti Matter Blue Lariat
I did the same . Everything is back up and working
stickyfingers
Sam
Toronto
Well I contacted the @Ford Motor Company on this forum through a PM and got a canned response from them as follows:
"Software updates are rolled out to different vehicles at different times, if you are concerned about the availability of a specific update, we suggest reaching out to the Service Manager at your local Ford dealer, they will be in the best position to assist you. In regards to your Ford Pass concerns, we recommend reaching out to our Ford Pass Team here: 855-542-7821. The Ford Pass Team will have the resources needed to troubleshoot your updating issues.
Ford Social Media Team"
I thought I was going to get some more help but it's a vicious circle. My app stopped updating, yet again. Because the app isn't updating meaning the trucks modem is acting up and the only fix at this time is to remove the battery terminal to reset it. If I don't do that I am not sure if I'll be able to get any new update.
I find this response absolutely useless. I expected more. Rant over. For now.
oh and btw: i was told by FordPass Support team that the update at the end of January will fix the problem. And, idk if it was the 4.1.1 update but clearly that didn't. Will see what the February update brings.
Greenhme
Jorge
2023 F-150
We will see what the Feb update brings in store. Wish Ford would setup mobile service like Tesla. I am sure that 80% of issues can be taken care of at the comfort of your home or business.
Arrington.LCA
Luke
Colorado
Did the same battery disconnect this morning and back up and running. Ford Pass app stopped working a day or two after my truck got 4.1.1 update. Wish there was more transparency on versions and being able to go back if there are problems.
Greenhme
Jorge
2023 F-150
App worked for almost two days and has stopped updating range and battery percentage again.
Reset fuse 32 on your body control will get it to work instead of pulling the battery. You will not lose all your radio presets. The body control module fuse box is on the right side kick of the passenger side.
BennyTheBeaver
My dealer pushed 2 updates to my truck 2 days ago, 1 for the Gateway and 1 for the DCFC system. I have a 2023 that I picked up in early December, haven't recieved an OTA updates.
I haven't had an issue with the modem seizing up yet, fingers crossed that Gateway update is a fix.
stickyfingers
Sam
Toronto
May have to take my truck to the dealer again.
Viet658
Viet
Pomona, CA
2018 Tesla Model 3, 2022 Lightning Lariat ER
I have 4.1.3 and have this issue as well.
jimfigler
Orchard park, NY
Mine stopped yesterday evening. which has happened in the past. Only once did I need to do the battery disconnect . Other times it just starts working again
