Frunk Fault Repair
emmelj
Jerry
DFW
2022 Lightning, 2018 Tesla M3
I have a 2023 Lariat Lightning ER. Last while driving home on the highway I suddenly had a dash warning telling me that the frunk was not closed and to safely stop and close it. I had just loaded items in the frunk and I used my fob to close the frunk. When I stopped to take care of the problem the frunk seemed to be completely closed. I thought I would open it and then close it again. However it wouldn’t respond to any attempt to open it. I tried to use the manual frunk release in the cabin but it wouldn’t completely release so I forced it shut and drove home.
After numerous attempts I finally manually got the frunk to release. The dash now has a Frunk Fault Service warning and a continuous frunk fault icon. I tried several things that I have seen on this forum to see if I could reset the issue but nothing worked so I called my dealer for service. The thing that really irks me, beside the frunk not working, is the dealer’s service department telling me that the earliest they can schedule the pickup is January 22! I’m really unhappy that it takes over 3 weeks before they will even begin to look at the truck. Itā€˜s a good thing that I was finally able to get the frunk opened and everything out of it.
Same thing happened to me. Dealer was 3 weeks out. Ridiculous. I just dropped it at the dealership and said its undriveable. They had it 2 1/2 weeks. Ended up being a rodent chewed one of the frunk wires. Replaced the whole latch, $700! Then the ended up breaking the plastic piece that is over the latch. Have waited about 1 month, parts just came in, and they tell me they need my truck for a couple days! Its literally a 15 minute fix!
lerthe61
Dmytro
Pennsylvania
F150L, VW
The described steps did not work for me. After the latest update, my frunk starts popping up just a little. So, I hoped I would be able to fix it myself.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi Dmytro! I can look into your Lightning's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN?
MikeT
F-150 Lightning Lariat
Try this:
1) Get a helper
2) manually pull release once from the cabin
3) have helper lift the trunk from under the front grab location
4) pull the manually release a second time while they’re lifting up
5) have helper keep lifting and pull A THIRD TIME on the manual release
The trunk should now fully open with the helper lifting it to the top stops
6) Hit the emergency release button
7) Hold the frunk open close button for several seconds until it beeps at you, this sets the fully open point again but probably isn’t necessary
8) Hit frunk button
9) Enjoy
10) Complain to ford that this isn’t in the manual correctly
Worked great!
