Frunk only goes down manually.
JDub
James
Oceanside
Last night, I started having issues with it not closing. It will open just fine with the app and from inside my cab with the dash button. Once it's up, I have to close it manually. It will not close with the button, app, or inside my cab.
Is there anyone else with the same issue? I searched the blog but could not find anyone with the same problem
Forum...
What happens when you push a button to close it?
JDub
JDub
James
Oceanside
Nothing. I will not close. If I hold it for a few seconds, I get a beep.
It will not close with all three options.
Mike G
N. AL, USA
Pinch sensor?
Heliian
Try opening height reset procedure.
See ownersanual for details.
JDub
JDub
James
Oceanside
I tried that, and it didn't work
Lytning
Georgia
As with other illogical issues, try lifting the positive terminal on the 12 volt battery for a minute or so.
Safer to lift negative and result is same.
PA Lightning
Tbone
PA
Lightning Pro
Just for giggles, make sure all of the doors are unlocked and try it again.
