Gear shift not disengaging.
Hamtech
Madison
KIA Sorento, Tesla X
Lawyer
I have 1900 miles on my Lariat. In the last two weeks the gear shift lock will not disengage with out forcing the shifter.
The issue will last for a few drives and then seems to correct itself to only remanifest.
Any one else experience this?
How do you force it to get it to move? Mine seemed to be locked and not move taking it out of park, but realized I was likely pulling on it some. Truly now - I push forward on it each time and it will come of out park each time. Might just double check and give it a little push forward before pressing the button and taking it out of park. Just one thought, you might have actual problems as many have noted how janky that shifter already feels.
cvalue13
Austin, Texas
ā€˜22 Lightning ER Lariat
Fun-Employed
I haven’t had that problem, but wanted to note that the shifter has a locking mechanism engaged when the truck is plugged into a charger.
accordingly, perhaps it’s possible there is something wrong at either the shifter itself, or instead at the charge port?
Watching thread to see what is learned
Ford Motor Company
Official Ford Account
Ford
F-150
Good morning. Can you please send over a private message with your VIN and the name and location of your local Ford dealer? I would like to take a closer look at your Lightning's shifting issues.
Hamtech
Madison
Lawyer
These all all good suggestion, and initially thought it was an operator error. However, the shifter now makes ā€œgear grindingā€ noises when you hit the retract button. Also, the issue is not exclusive to shifting out of park, which would be emblematic of brake light switch issues that have plagued early 2000 VW and Subaru.
In regards to forcing, I have to use an excessive amount of force to shift. For an EV this is odd because the is nothing mechanically being engaged to shift gears. There should be little to no resistance. I have a Tesla Model X and drive enhancement is a stalk that has zero mechanical function.
Reactions: GDN
Hamtech
Madison
Lawyer
I will report back. The issue occurs when the truck is not plugged in. Occurred yesterday in a parking lot. I am perplexed by the intermittent nature of the issue. The issue also occurs with different drivers so it is unlikely to be an operator error.
cvalue13
Austin, Texas
Fun-Employed
yes sorry, I didn’t mean to suggest it was happening because plugged in, but instead only to point out that whatever is telling the truck to not move the shifter, it’s theoretically possible the issue is occurring at either the shifter itself or possibly instead ā€œatā€ the charge port, effectively making the truck think it is plugged in when it’s not.
no clue, of course, if the ā€œplugged inā€ signal is mechanical (ie something at the charge port is physically moved when plugged in, thereby signaling the shifter to not move) or instead the signal is completely software based (ie when the truck knows it’s otherwise charging, it signals the shifter to not move).
