Got to 2%, 5 miles to go - then I experienced something I didnt
Rocket808
Rocket808
Rocket
Los Angeles
what is your charging pattern if you don’t mind me asking ? I know that if you do a lot of DC fast charging i.e. on a long road trip the BCM can get out of whack and the percentages be off a little bit…( such as what happened to the out of spec guys on the EA race) … not sure if it also happens for those who do not charge often… I noticed my percentage hopping up and down after mine sitting for a few days…. I usually don’t plug in till I’m about below 50% ? And I wonder if level two charging to a high state of charge balance is the cells…. And helps recalibrate the bcm?
I personally charge nearly solely on AC using FCSP to 80% daily “ABC”. I did DCFC in the beginning of getting the truck awaiting my system to be installed.
So typically DCFC is limited to road tripping - probably charged to 80% 10 times in the past 18 months on EA and now Tesla.
gbuydos
Central Iowa
F150 Lightening Flash '24
The one thing i did like about my Toyota RAV4 EV was it had turtle mode. Basically at bottom of the SOC it went into turtle mode, this allowed you up to about 20 mph for a few miles to limp the vehicle home or a charging station. With a max 108 mile range, i used it a few times.
fhodgdon3
Franklin Nichols
2024 F150 Lightning Flash
cabinetmaker
This winter I was driving home and my battery got down to 3%, at a stop sign 200' from my driveway the truck shut down, wouldn't budge. I sat there thinking how many feet of extension cord I had (for maybe 60 seconds) then I tried again to start it, luckily it "limped" into my driveway. Won't let that happen again. Certainly have to be way more vigilant here in New England during the winter. It dropped from 10% to 3% really fast at around 15 degrees out.
hajalie24
2024 F-150 Lightning Lariat Antimatter Blue
You know, on my most recent road trip the weather got cold and the estimated percentage for when I got home kept dropping.. At first Google said we would get there with 15% range but it got down to 7% and would have kept going down. My wife got worried so we stopped to charge at a slowish DC charger, added 14%, got home with 16%, so we would have gotten home with 2% and I thought that would have been perfect and we didn't need to charge.. Well now I'm glad we did, especially since it may have limped on while still on the highway...
Next time Google Maps suggests charging cause we'll arrive below 10%, I'm going to do it.
Rocket808
Rocket808
Rocket
Los Angeles
I agree. I will not push it thinking “it’s greater than zero %.”
It sucks to stop, but even 5 min at a Tesla supercharger pulling 172kW gives some buffer.
I have wanted to push mine down into the low single digits, just to help calibrate the BMS, but have been afraid to do so. With the reports of SOC suddenly plummeting below 10% i could be local and still not be able to get home, or to a charger
