Heater question during charging....
No, it was on accessory mode... if it's that simple I feel stupid. We should still be able to run heat while charging with ACC on. That seems intuitive.
In reality, there’s no reason to even have an ACC mode in an EV. As long as you’re not driving, it’s in ACC mode.
If it’s “On”, everything should work.
lightspeed
2023 Lightning Lariat ER
Yeah don't know why they do it that way, but Ford's history with gas is long, so they emulate the behavior of the ICE trucks.
Amps
Mid-Atlantic
Bolt
Do the HVB contactors close in ACC mode?
If not, you wouldn't want the HVAC load on the LVB.
Nick503955
Nick
San Diego, CA
2023 Ford Lightning Lariat, 2024 Kia EV9
Tesla figured this out.
Pod
2023 AMB Lightning XLT SR
I had this heater issue today. Got in the truck after work and took off. Noticed cool air, turned up control to 80°, only mild change. Got out, ran quick errand and back in. Still rather tepid. Curious what will happen in the morning. Not charging tonight as this is my first week to see how long I can make it with one or two charges.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
My truck is still retarded.. 74degrees is blazing hot. Not just when I first turn the truck on but after driving for 30min. The temp sensor seems to not be registering actual temp.
xgonzo821
Jay
2024 Ford Lightning Lariat
Hi, this was happening to me when I charged where the heat wasn’t working and I was just sitting there with cold air blowing at me. What I did was I unplugged the charger, turned the vehicle on (if it wasn’t already on), turned the heat on, made sure it wasn’t blowing heat and then plugged the charger in. This kept the heat on the whole time I was charging. Hope that helps!
