Home Assistant - Ford F150 Lightning Dashboard.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
This one is nice as well. Mind sharing? Or was this one already posted earlier?
I've taken parts from quite a few - one originally posted here I believe. I don't mind sharing. I also have some templates made, included in the GIST.
EDIT: Make sure to change your device ID in the `navigation_path` lines if you copy these.
linuxgangster
shane
2023 F150 Lightning xlt
Where is the navigation bits coming from?
queuewho
Western PA
22 F150 Lightning Lariat SR
I set mine up about 2 months ago and it’s been working fine.
You must clear out any downloaded version via HACS and then manually install 1.70 per repo instructions.
EDIT: image
Did you just scp into your backend files and copy 1.70 into some specific folders? Didn't see specific instructions on the manual install.
IIRC I just downloaded the files from the GitHub site and then overwrote the same files on my HA box but keeping my existing token file there.
\config\custom_components\fordpass
queuewho
Western PA
Thanks I'll try poking around in the container later.
Aminorjourney
Aminorjourney
Internet
vehicles that go
To add my voice back into this - sorry -I've been avoiding social media and forums of late because... *things* - I'd note that this integration does now require you to do a little leg work to keep it working.
The GitHub is pretty clear now - https://github.com/itchannel/fordpass-ha - but I would advise if you're anything like me to read it a few times before you try anything, otherwise you will end up scraping your head and screaming.
My system has been working with V 1.70 for literally months now and it's great. I don't have a very frequent refresh interval on purpose, because really what I use this for is remote starting of our Truck on a cold morning or hot afternoon.
We also use it to pipe info to our smart display switches so we can see at a glance how much range each of our EVs have (my bike hasn't got telematics... sad face)
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7112
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7110
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7111
linuxgangster
shane
Same with me. I just got my truck and this integration going. I pay more attention to the automation I have built with the Emporia Vue and EVSE along with Solar Assistant. Right now I am refining how I am automating the EVSE to charge my truck based off of my House battey SOC and calculating the excess solar. I wish the Emporia Vue could do what I want but this gives me an excuse to code something. Right now its pretty close to how I want it, I just need to weigh rather or not its worth my time to do it in a more geeky elegant way.
Well based on my file dates, I'm running 1.68 using a token file. It has been working since May 10. But yeah, you should probably use the 1.70 instructions.
zinkscott
Christian
Cloud Engineer
2023 F150 Lightning Platinum
Got my integration working today as well. Thx for the valuable input from here. Used the repository marq24/ha-fordpass to install the branch via HACS (does not require copying files).
My Dashboard right now looks look that way:
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_0441
