tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
I have seen where the inverter can get a low voltage fault. Assuming you are testing exactly the same as when it previously worked, I would just try again. Using the m-professional app while testing the system would give some insight into what is going on. The fault on your charger is just a secondary symptom of the inverter fault, and I would not worry about it.On my first system test since installing the latest software version 1.1.34 on my systems inverter, I had negative results. On my second attempt of unplugging and reinserting charge cord into charge port the led light circle did turn green and start to pulse. On the intelligent backup screen on the truck it was showing the pulsing green from the truck to the house. The charger was showing a steady green then a pulsing green. The inverter did its usual clicking and started to hum as though power was being transferred. The only problem, house power never actually came on. After a few minutes the inverter humming stopped even though the led lights on the charge port continued to pulse. A single amber light then lit on the charger right side of led light bar. From the chart in the Pro charger manual this indicates a fault and troubleshooting is required. This seems quite coincidental that I am now getting a fault light in my charger on my first test since installing the latest software on the inverter. Before the inverter update i was always able to get the system to work using the charge cord trick as discussed in the Home Integration threads. If anyone can share some insight, it would be appreciated.
I don't think the software version has anything to do with this fault. I have had the low voltage fault 2-3 times in the past on various versions of firmware. When I went back on-grid and then off-grid to test again it has worked fine.
