How often do you actually use the 9.6 kw pro power on board?
funny
my wife ordered her an interesting 'USB-charged battery-powered CURLING iron'
for her car, while she 'travels'...
really?
I told her we had an outlet, if not MANY outlets, in our truck... full 120v outlets.
"oh", she said, "I got this for my EV9"...
well... I said, "Dear, you have an outlet in the car, too"....
oh well.
Jseis
SW Wa
Yes, house backup but more.. to charge hand portable tools, run a small 120V compressor, chop saw, reciprocating, grinders. Might as well use the good old corded tools. My older farm has limited power and its very useful there. A reel or swing out cord reel that could reel up 100’ w/3 receptacles would be nice or maybe a heavier cord to a separate utility panel on a transfer switch. That’s the ideal.
To be honest something like the 9.6 Pro Power is one of the biggest selling points of this truck. It's very sad Ford doesn't include it on every one. If they've got to reduce value and raise prices then things like the scales are the easiest and most gimmicky things to get rid of. Of course I think they've done both.
Firn
23 Pro ER
Here is a copy and paste describing our setup. Been working great for about 18 months.
"When I installed our transfer switch last September the plan was just to have it for backup. Then it morphed into powering our house from 4:00 pm to 8:00 pm when our utility rates skyrocket (we are on the EV time of use plan so have the highest peak rates). Once I discovered that the Lightning would power our 5 ton AC and could go several days powering our house without charging we started turning on the Pro Power every morning we are in town.
Our transfer switch is kind of a Unicorn. It's automatic and switches the neutral and has a switch for instant transfer or 30 second delay. It's only 50 amps but that has not been a problem. Basically it's designed for a 50a Class A RV.
We have identical dual panels since we finished the basement 14 years ago. The transfer switch feeds the sub panel with a 50a breaker. The sparse sub panel is now full and the main panel is sparse. We are powering our entire house from the lightning with the exception of our 4 ton upstairs AC system, dryer and a handful of mostly unused outlets and lights.
With the Lightning ground connected to the transfer switch we would get periodic ground faults at the lightning when our 5 ton AC breaker was on. This AC unit is inverter driven and full variable which is the only reason the Lightning can run it. I went through the wiring completely and it is correct, tight, no bugs and no moisture. However, these Inverter units are much different than a tradition AC so no idea why it can cause the Lightning to ground fault. The Lightning cannot start our conventional 4 ton unit.
I finally gave up and dropped the Lightning ground at the transfer switch. All we have to do in the morning is remove the charger, turn on the truck/Pro Power and done. My wife does it most days at about 6:15 am before she makes coffee. Alexa reminds us every night to reverse the procedure.
I am at peace with removing the ground for the reasons stated by others above. Truck is in our attached garage.
When my wife retires in a few years we are selling and moving somewhere with mountains and low humidity. I will remove the transfer switch and move the breakers back to the main panel.
If you came into our house you would have no idea it wasn't running on grid power.
From Midnight to 6:00 am the grid powers our home and charges our EVs at 2 cents per kw in the winter and 3 cents per kw in the summer. On the rare occasion that we have an extended power outage we have backup power on par with super expensive Generac install.
We like sleeping in a cool environment so in the summer our programable thermostats blast all floors with cool AC from Midnight to 6:00 am at .03 cents per kw. Even on 100 degree days our house stays nice and cool until mid afternoon. Then main AC kicks on powered by the Lightning.
Our retirement home will be much smaller, much nicer and much better built. It will have V2L and whatever truck or powered RV trailer is capable of powering it. For now I love our inexpensive system (obviously ignoring the cost of the Lightning).
DISCLAIMER: Don't even think about putting in your own transfer switch unless you have experience working in main breaker panels with hot utility power."
Any sense of the savings realized by going this route?
How much does your battery deplete during the day?
Hammick
Somewhere in MT
Only been doing this for about 17 months but between $1,200 - $1,500 per year depending on how hot the summer is. This time of year when I'm not running any AC it uses about 12% per day.
Obviously my approach won't work if your Lightning is your daily driver or if you don't have time of use rates.
