csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
So, using one ring would give a 2" drop? Would that require the camber kit?
Hard to tell with settling exactly but no rings is a 2" total drop (3" shortening of the strut) and two rings is 1" total drop which is perfect
Neverstrikestwice
Jeremy
2023 Lightning platinum
All, just did this project. Makes a HUGE difference. Pics don't do it justice. The truck just looks right now. I put together a how-to for others who might be interested. Cheers!
###UPDATE### 22Sep - After driving for about 1500 miles, I can no longer recommend doing the full 3" suspension shortening/2" rear drop level, but instead you guys should do a 1.5" suspension shortening ( 1" drop. ) You can do this by adding two of the 5/8" steel rings to each strut tower, included with the shocks. I did this change today, and glad I did.
1) With 3" shortening (2" drop) described in the original post, the ride does take a significant hit and is not longer very comfortable. That 3" of suspension travel you take out is ALL the comfort, beyond that compression is for heavy loads only. Feels like my old ICE truck with stiff rear leaf springs. Bouncy and hits hard.
2) The negative camber is unacceptable. Mine was 2.5-3 degrees after leveling. There's no way to adjust it on Lightnings without frame modification. You have to remember that this suspension travels on an arc. The more the suspension is shortened, the more the control arm rotates around its axis and forward in the wheel well, and creates negative camber. It rode worse, was louder, and my efficiency took a hit by not riding on the tires square.
3) The good news! By doing a 1.5" shortening (1" drop), compromise is best! You do this by adding two (2) of the 5/8" steel rings to the shock body. This functions as a spacer. There is virtually no camber difference in a 1" drop, its still within spec, it does look significantly better with reduced (but not eliminated) rake, and rides *much* better. I'm very satisfied now.
Bottom line, ride and negative camber get exponentially worse with 3" shortening (2" drop) and you can keep the ride and improve the looks by only doing a 1.5" shortening (1" drop).
Off topic but where did you get those caliper covers from??
csukoh78
Nope
SE USA
RC truck parts. They are awesome and high quality but the red clashed so I took them off. May powdercoat them black one day.
sr3jan
Jeff
Atlanta, GA
23 Lariat
@csukoh78 moving our conversation to this thread. Following up on the camber kit. Have you installed it yet? And, as others have mentioned, thanks for putting this together.
csukoh78
Nope
SE USA
You're welcome. Yea it's installed as part of the icon kit
sr3jan
Jeff
Atlanta, GA
23 Lariat
Oh, I didn't realize you obtained the full Icon kit? Do you still recommend the Belltech option? I noticed a few reviews on Amazon claiming that the Belltech units do not hold up long term, that perhaps they are not designed to handle the weight of this truck.
csukoh78
Nope
SE USA
yeah I wouldn't necessarily trust an Amazon review. The strut does not bear any weight… The weight of the truck is suspended by the truck springs. the Belltech kit is just a dampener and it worked very well on my truck, no issues for 20,000 miles before I switched it out for the icon kit.
csukoh78
Nope
SE USA
O.L.
Joël
Quebec, Canada
2023 Lightning, 2022 Mach-E, 2018 Mazda CX-5
Manufacture worker
Better late than never. I've just ordered them. Going to install them end of October at the same time as installing my winter tires.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
So how did it turn out ?Just read in October. NM.
O.L.
Joël
Quebec, Canada
Manufacture worker
@csukoh78 I just installed them. I used only 1 sleeve to try the 2 inch drop. You said none was too much and the photos that you showed with two sleeves wasn't enough for me. Going for an alignement in the next days. I'll take pictures tomorrow.
csukoh78
Nope
SE USA
Good luck, let us know how you like it. You're probably not gonna like the amount of camber that you have, you need to get the camber adjustment kit from Icon.
Schmitty
Kyle
St. Croix Area
2023 Ford F-150 Lightning
Thank you so much for your post and instructions on the install. That is a huge help. I have a 2.5" lift/level on my 2023 Lightning standard range and now want to take off the 2.5" leveling puck to now lower my Lightning using the Eibach lowering springs, Icon camber kit and Belltech 25001 struts for the rear. I just had a couple questions if you don't mind answering and that is has anyone paired the Belltech 25001 struts with the Eibach spring? I really want a perfectly level stance and with having a standard range battery, with installing the Eibach front lowering springs I am down -.3" and will need to lower the rear 3.3" to match the front and I will achieve 2.3" drop from the Eibach spring and can utilize the other 1" drop from using the spacers on the Belltech 25001 struts correct? I believe I can achieve that 1" drop on the strut by using 1 of the 16mm shims if I am understanding the geometry correctly. Any help is appreciated! I also want to keep my wheel and tire setup which will require some trimming since I have 22x12 wheels with 325/35r22 tires for a more aggressive/non-aerodynamic stance 🤣
Ford F-150 Lightning HOW TO DIY -- level / lower rear suspension on Ford Lightning using Belltech 25001 IMG_1384
Ford F-150 Lightning HOW TO DIY -- level / lower rear suspension on Ford Lightning using Belltech 25001 IMG_1385
Ford F-150 Lightning HOW TO DIY -- level / lower rear suspension on Ford Lightning using Belltech 25001 IMG_1386
Ford F-150 Lightning HOW TO DIY -- level / lower rear suspension on Ford Lightning using Belltech 25001 IMG_0631
Ford F-150 Lightning HOW TO DIY -- level / lower rear suspension on Ford Lightning using Belltech 25001 IMG_0755
