sonofzell
- First Name
- Kirk
- Mar 4, 2021
- Philadelphia, PA
- '21 F150 XLT Sport 2.7EB SCrew 302A High
You know, the one that gets referenced frequently on these threads…. The "weekend warrior" idiot pulling a camper with absolutely no idea what he's doing. Yup, that might be me. I've come to the realization that I've been severely (and arguably, dangerously) underestimating the importance of towing properly, so I'm putting myself out here to hopefully get sorted out (and take any abuse I deserve in the process).
To be fair, I've towed often through the years, but nothing of any considerable weight or size. I've pulled & launched boats from 12' to 30' (using others' trucks), and the occasional utility trailers ranging from 8' to 15' using multiple vehicles. The only "regular" tows I've owned prior to a few years ago were a couple of 16' pop-up campers, neither of which ever gave me any issues. I've towed those with the F150, a Pathfinder, and even at one point - a Ford Escape!
So a few years back, we upgraded our rig to a 24' hybrid-style conventional camper. At the time, I had a 2018 XLT 4x4 with trailer tow package. The entirety of my towing "prep" consisted of adjusting the hitch drop and installing/calibrating a brake controller. I'm now in a 2021 with identical specs (XLT, 2.7eco, trailer tow pkg, 3.55 ratio, 4x4), and pulling the same 24' camper. Since diving into these forums and seeing all the discussions regarding payload/tow capacities, weight distribution, sway control, etc., I'm reluctantly realizing how little I REALLY know about what I'm doing when I hook this thing up!
Now here's the rub: In my perception, I've don't have any towing "issues". 95% of our trips with the camper are within 100mi, with only a handful in the 300mi range. I'm a relatively conservative driver to begin with, and I'm damn-near neurotic when it comes to driving as safely as possible with the camper in tow. I've not had any complaints at all in terms of acceleration/stopping, excessive sway, or control when towing. I rarely break 65mph when pulling the camper, and make it a point to drive excessively (or 'annoyingly', according to my wife) cautiously when towing. The ONLY noticeable behavior I've found when towing with my current/previous F150 is a bit of "bounce" felt after a dip or bump on the road.
I'm equally confused and embarrassed at how the use of weight distribution systems/sway control devices and tongue weight calculations just seem to be "common knowledge" among most of the users here. What's worse is that the more research I do, the more I'm wincing at how little I actually know about towing safety procedures!!! Other than tire/axle/bearing maintenance of the trailer itself, I honestly have never concerned myself with anything other than keeping the camper level, keeping any interior cargo above the axles, and not driving like an idiot.
Given the variables above, I suppose my question is: what should I be doing to ensure I'm towing properly and safely? The immediate questions that come to mind include (but certainly are not limited to):
I've been picking the brains of guys I know personally that tow frequently (daily in some cases); everything from landscape flatbeds to 50' fifth-wheels. The responses have been all over the place. I even talked to one guy with the most elaborate hitch setup I've ever seen - but couldn't really explain a thing about it. "It's what the RV dealer said I needed" was the extent of the info he offered.
Obviously, my RV dealer was pretty lax on the towing requirements lol…. I guess before I ramble on any more, I'll just throw these specs out and thank you guys in advance for any insight you can offer…
My Truck:
'21 F150 XLT SCrew, 2.7eco, 4x4, Trailer Tow pkg, 302A High, 3.55 ratio
My Trailer:
24' Conventional dual-axle w/ electric drum brakes (Exterior: L=24'10", H=10'3", W=8'6")
Axle weight: 3635 lbs
Dry "hitch weight": 630 lbs
Dry weight: 4265 lbs
Payload capacity: 1840 lbs
GVWR: 6000 lbs
"Hitch weight": 660 lbs
*as for camper payload, I'd estimate there's approximately 200-300lbs of our "crap" that resides in the trailer, less on return trips (when the cooler/fridge are empty lol). This is also considering all holding tanks are empty, as I have only used the (40 gal) fresh water holding tank once.
*any interior cargo is deliberately kept as close to the trailer axles as possible.
*truck payload can vary trip-to-trip, but rarely exceeds 100-200lbs. An exception to this rule is when I occasionally pick up a load of firewood before setting up at our regular destination, but it's only 1.5 miles between the pickup and the campsite. I myself flutter around the 200-215lb range, and most often end up towing alone; potentially there could be an additional 200-300lbs combination of kid(s)/spouse/dog in the cab.
- Do I need a weight distribution mechanism?
- How exactly do I calculate tongue weight?
- Is sway control something I should consider if I don't necessarily feel sway is an issue when driving? Would this be redundant considering the truck's integrated anti-sway system?
- Are there any signs of overload/imbalance that I should be monitoring for (perhaps I've simply 'missed' evidence of improper towing in the past)
My Truck:
My Trailer:
GVWR: 6000 lbs
