JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
I run mine at 42psi, recon grappler SL P275/65/20
Not to continue off the original topic, but this is a valuable discussion about tire pressure.
I had the general grabbers stock, door sticker says 116T 42 PSI. I put on Bridgestone dueler ascent A/T which are 115T. The person at Discount Tire said yo use the same tire pressure since it was the same size as stock. So those are at 42-44 when I check. Should I lower that to 36? I assume that means the TPMS would also need to be adjusted.
JerseyMike
Allentown, NJ
I would still run them up there, will help with range too....in terms of TPMS, no need to recalibrate them, it is the truck computer that determines acceptable range and that can be changed with forscan
Nikola 369
Pella, IA
2022 F150 lightning Lariat SR
Sales Engineer
I guess at this point I would check the side wall of the tires to see what pressure is max? I wouldn’t want to run tires close to max PSI knowing they will increase with temp. If the 42-44 is close, I would follow Fords lead and have them set like the stock 115T’s were @36. When Ford had this issue, it wasn’t related to tire size, but rather the load rating between 116T & 115T. Maybe the store guy didn’t Full understand the issue Ford had. There’s a few hundred pounds difference in load range between those tires and the higher pressure could be an issue over time if close to max rating.
Running at max should be no issue. There is a very large factor of safety here. The tire manufactures have to plan for people hauling at max capacity and starting off the day with cold mornings and driving into hot days.
Nikola 369
Pella, IA
Sales Engineer
I’m only suggesting caution and keeping the margin wide. I have driven a couple million miles to date and never had a blown tire. I know so many people who have, sometimes related to a load within load rating. Other times for no explainable reason. You have to question pressure. Ford learned a really painful lesson in the past on this issue. To make a softer smoother ride, they suggested lots of vehicles run 26PSI on tires rated 32-35PSI………. It didn’t go well, lots of blowouts, some roll overs, and many millions of dollars in wrongful death suits. I suggest caution and trying to stay close to ratings by OEM and tire manufacture.
We can talk all day about safety factors and margins, but unless someone has the engineering from the tire OEM, then it’s just talk. In another job field, I used to inspect overhead cranes in the maintenance field. 40 yrs ago, manufactures used to use a safety factor of 15-20/1 for failure ratings. 25-30 yrs ago, it was changed for unknown reasons to 10-12/1. Now somewhere mid to late 2000’s, European manufacturers started selling state side and buying out other USA manufacturer. There is one, I won’t mention the name, that uses 3/1. Sharing this information, which system do you want to be in the same building with? Caution goes a very long way to preventing a varied result.
AlexM
Alex
Colorado
2023 F150 Lightning XLT ER
I got the Toyo AT EVs for our truck as well (stock size, 275/60/R20). The stock tires weren't doing it justice in the snow. These tires have been great. Definitely improves the look of the truck in my opinion. Here are some high level thoughts:
  • Noise: noticeable compared to the stock tires but not significant. Overall, less than expected and very pleased. After a day or two I stopped noticing it.
  • Efficiency: Doesn't seem to be any significant effect. It's hard to say as it got progressively colder after I installed them so range was being hit regardless.
  • Ride Quality: this has actually improved in my opinion.
I have owned a number of AT tires on other trucks in the past, and these are by far the quietest. I don't expect them to work quite as well in the snow as the Goodyear Wrangler Duratracs, but in the few small storms we've had I've had no issues.
Ford F-150 Lightning Installed Toyo Open Country AT3 EV 116 T XL All-Terrain Tires IMG_0707
