Module Updates - Truck runs better?
speedracercjr
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
My question is, when you updated the PCM, did you reset the adaptive shifting tables? Because doing that always results in better shifting to me.
I did not, but I will do that the next time I have an active FDRS subscription
wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
Sorry let me rephrase the question...
Does updating the PCM also reset the shifting tables, which is why the shifting feels better/smoother? Because if yes, that means that, by itself, updating it isn't going to be helpful.
If no, then that's great news because it implies there's newer, improved shifting logic built in.
speedracercjr
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Oh great question. @Jesse-Infotainment @iceman77 any idea if this happens?
Jesse-Infotainment
Jesse
2021 F150
yes it does if you disconnect your battery for while it resets as well
Icecoldak
Steve
Alaska
2019 F-150 Limited
Are all you guys updating your modules using the FDRS method or the dealer?
Icecoldak
Steve
Alaska
2019 F-150 Limited
So using the FDRS method you can update every module in the truck!
capitals25
Matt
2021 Powerboost Platinum
When I was in for service a couple weeks ago, I mentioned frequent clunky shifting and also bad stuttering when giving gas on slight highway incline around the 55 MPH mark. They said that Ford asks them to wait until 10,000 miles before they'll do much investigation on the transmission because it can take that long for the ECU to settle in. (I'm at 7,500) Seems way too long for that to make sense, but maybe I'm wrong.
Saw this thread and wondering if there are more widespread reports of improvement after these updates. The harshness of the shifting is so bad sometimes that I'm concerned about long-term damage to the transmission.
Thought about just doing an ECU reset by unplugging 12v batteries, but not sure if that in itself is enough to see the improvement. (Anyone know the correct way to detach BOTH 12v on the PB?)
Also curious if I end up waiting for the OTA or if I ask the dealer to update, will that do all the updates that might be part of the ride improvement?
Appreciate any info or feedback.
Autofill
US
F150
I had my dealer perform this TSB and the harsh shifting has pretty much disappeared.
https://ford.oemdtc.com/7501/10r80-...sh-electric-to-gas-transition-2021-ford-f-150
Ford Motor Company
Official Ford Account
Ford
F-150
Good morning, Matt! Could you please send us a private message with your VIN and dealership information? I would like to look into these transmission and OTA concerns for you on my end. Thanks!
Jesse-Infotainment
Jesse
2021 F150
Do you just disconnect the negative on the battery for the Powerboost hybrid? Is there more to it for the hybrid? Thx.
oh no don’t do that with PB
Jesse-Infotainment
Jesse
2021 F150
Sorry I just don’t suggest anything with the PB battery because damage can occurs with not disconnecting them correctly.
