rolker
- First Name
- Roland
- May 26, 2022
- New Hampshire
- 2022 F150 Lightning Lariat ER
- Occupation
- Software Engineer
Thanks for the links! Interesting reads. They seem to show up as images for me so here they are again:
https://www.rvtravel.com/rv-electricity-why-neutral-burned-up/
https://www.rvtravel.com/rv-electricity-pedestal-power-basics/
I guess the moral of the story is to bring a multimeter and verify volatges before using a campground pedestal?
Should a pedestal with the three kinds outlets have a supply that can handle 100 amps? Of course, "should" and what actually gets done can be very different things.
Anyway, I did test at home running the camper from the Pro Power while charging from a 14-50 outlet so that's an option. Of course, it's a bit simpler if I can just plug both in the pedestal.
I've read of people using the 14-50 240v to charge their Lightning & use the 30 amp 120v for the trailer. I think we run the danger of overloading the wiring at the pedestal doing so. I think the safest way would be use the 14-50 240v to the Lightning & run your trailer from the Lightnings Pro Power connection.
Two 120v 30 amps at one pedestal can cause you problems with charging & probably won't charge at all (because they are probably the same phase) & a danger to your trailer if you try to connect it as 240v using both 110v 30 amp connections. It has the potential of over current on the neutral wiring of your trailer & the incoming wiring. This articles link does a good job of explaining why.
This article explains basic camper pedestal wiring.
This diagram shows the normal wiring on a pedestal.
