FlasherZ
St. Louis Metro
I sure appreciate everyone sharing their knowledge around here.
These are all topics I do not understand, and won’t anytime soon - but hope to keep following and pick something up.
The conversations are far enough above my head that I hoped someone might clarify for me: am I understanding correctly that, if powered by the Lightning, GFCI’s will have a problem; or is it the other way around, that if plugged into a GFCI theLightning will have a problem?
Appreciate the hand-holding in advance
A little bit of both.
But what we've been talking about here is that if you plug the Lightning's mobile connector into a receptacle protected by a GFCI OCPD (breaker) you may end up with nuisance trips of that breaker.
And the 2020 version of the NEC now requires that all 50A receptacles in homes must now be protected by GFCI OCPD's, so we're probably going to see a bunch of nuisance tripping and troubleshooting while they work out bugs.
ExCivilian
'22 Lariat ER, '22 Platinum
Professor
Have you confirmed your state/municipality has adopted this section of the code? CA, for example, doesn't adopt TIAs and this won't be relevant statewide until 2023.
Also, we need to confirm our EVSEs do not already have GFCI internally. The installation manual will tell you whether the device has internal ground fault protection and it will say whether one ought to direct wire it to a GFCI breaker--I've personally never seen one that did even when it was lacking internal protection. Every approved EVSE on the market I've seen has it and I suspect every EV on the market already has ground fault protection because the manufacturers don't want to kill anyone. That said, I'm not an electrician by trade or hobby so I can't speak to how representative my sample was. I can say, however, that 6+ years ago there weren't very many on the market and the ones that dominate the market now were fledgling back then so there was a lot more focus on what was inside the boxes back then.
I don't think the issue is resolvable without revision of the code. It seems the manufacturers of devices and EVs already tend to implement ground fault protection and duplicative GFCI causes issues. Ran into similar issues when installing solar in 2016. The state, the city, the fire dept. all had their own requirements regarding physical disconnect. SolarEdge inverters had them built-in...so I ended up with a wall of disconnects!
Oh, and maybe this whole conversation won't matter to some because...have you looked up the cost of a 100A GFCI?!
Griddlez
Griddlez
Metro-East of St. Louis, MO
And the fact the Ford Charge Station Pro manual explicitly says do-not use a GFCI setup with it. Well that's 80 amp and not exactly the same, but more confusion for sure!
ExCivilian
Professor
That's one of the chargers I'm referring to. The 80A EVSE would require a 100A GFCI...if it required a GFCI breaker. Problem is that inspectors, at least in my past experience, weren't willing or able to deduce that if the device has what is called for it's unnecessary to require another. That's how I ended up with a wall of disconnects.
I'm planning the solar install on our house over the next few weeks and I asked whether that was still the deal and my installer said that they've thankfully figured it all out and I wouldn't end up with a wall of disconnects. That said, this stuff goes both ways: their design team keeps plastering 36" pathways all over the roof planes of my house even though CA has reduced the requirement.
FlasherZ
St. Louis Metro
All EVSE's have been required to have ground-fault protection for many years.
But that protection is only present on the J1772 end of the EVSE. Supply conductors - for example, grabbing the plug too tightly so that you touch one of the hot prongs as you insert or pull it out of the receptacle - are not protected against ground fault. This is one of the aims of GFCI protection on the receptacle itself.
It's one of the complaints I had about the second-gen Tesla mobile connector - the plug is too flat and it's too easy to wrap your fingers around it and hit the prong as it's coming out or going in...
Frankly, if they make it work, I'd love to see the super-short cord length requirement on the upstream side go away for EVSE's.
As for the cost - it's why I (half-)jokingly said that some people say the new code requirements are because the manufacturers aren't making enough.
ExCivilian
Professor
Is that level of protection necessary for a hardwired EVSE?
Also, thanks for that info. I did not even consider that a GFCI would protect against that scenario. I try not to mess with raw electricity.
FlasherZ
St. Louis Metro
Not really... and the 2020 NEC doesn't require GFCI for hardwired equipment - only receptacles into which EVSE's are plugged.
ExCivilian
Professor
What the heck...of course it doesn't! I've been stuck on stupid thinking it's about all EVSEs requiring GFCI protection rather than their relevant outlets. Thanks for clearing that up.
Clearly it's been a long day for me :p
rolker
Roland
New Hampshire
Software Engineer
rolker
Roland
New Hampshire
Software Engineer
This past weekend, we took the camper out for real on a short trip to camp in family's backyard in Mass.
The trip there was 72 miles and we drove about half of it on highways and half off highway going trough New England towns (Slow, many stop lights). I was wondering if we could make it there and back on a single charge, at least theoretically, so I stuck to 55 mph on the highway.
Leaving Friday evening, I put the truck on the charger when I got home from work to top off as I finished packing the camper. Left with a 99% SOC, arrived with a 48% SOC and averaged 32 mph taking 2h 31min. That included a quick stop for provisions where I left the truck "running" to keep the wife and toddler comfy.
Looks like around 1.08 miles/kWh at that leisurly pace.
Without a 240V outlet at our destination, we took advantage of a nearby free public L2 charger to charge up to about 70% and a bit of local driving brought us to 65% by time we left to come home.
The return trip included a wrong turn (easy to do on New England roads!) that cost an extra few miles and a longer stop with the truck "running" while I dumped the tanks.
79 miles in 2 h 47 min averaging 28 mph going from 65% to 5% SOC.
The return trip's rate was about 1.01 miles/kWh.
The average speed is probably slightly underestimated since it looks like it includes the time spent unhitching at the destinations.
The above data was collected using ABRP with an OBD dongle so I could train ABRP with a "camper" profile. The resulting reference consumption at 65 mph is 0.9 mi/kWh or 1,111 Wh/mi.
My standard, non-towing reference consumption in ABRP is 2.29 mi/kWh at 65 mph.
Conclusion: With a similar camper as mine (31', 7700 pounds max), don't expect to get even half your non-towing range even if you slow down and avoid highways.
Next time I make this trip, I'll try the usually suggested route where I495 is used for a good portion of the route and I'll try to match the lower end of traffic speed which tends to be in the 65-70 mph range.
EvEddy
F150 Ligthning
rolker how did it feel towing? I have a 7200lb 35' travel trailer that I tow with an f250 but before a couple times with a f50 hdp and it felt a bit light. I presume the lightning is heavier but does the short wheel base make the 31 trailer feel heavy?
rolker
Roland
New Hampshire
Software Engineer
It felt better towing with my Lightning than it did with my 2018 F150 that also had a crew cab and short box. On the highway, I felt much less swaying when going by tractor-trailers. I'm still amazed at how I can merge on the highway or accelerate from a stop light while towing as quickly as general traffic.
I haven't tried towing this trailer with an F250 or anything with a longer wheelbase than the Lightning so I'm not sure how it compares with them.
greenne
Nathan
Niskayuna, NY
FWIW in NYS my EVSE installer recommended I hardwire the unit to avoid having any issues with the GFCI(which apparently is required here in a garage install of a 50A outlet).
Also to note..he also did say a separate shut off switch is also required for the EVSE so I have a large circuit breaker installed just to the side of the EVSE. The 60A circuit has a breaker on the panel, and then a local breaker right next to the EVSE. (Installed a chargepoint 48A EVSE hardwired)
Just passing that along.
Ford F-150 Lightning My first test towing a 31' camper with Extended Range Lightning Lariat 20220912_131905
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
After watching many towing videos featuring both the Lightning and the Rivian, I figured that the range I can expect towing my own camper would be half or less. Well, to know for sure, I hooked up my trailer for the first time and went for a test drive. It's 31' long and probably weighs about 7000 pounds.
Noticing on Plug Share that a Rivian had checked in at EA in Manchester, NH, while towing, I decided to also incorporate my first DC fast charging to the outing.
I left Epping, NH with 79% SOC, got on the hiway and set the cruise control to 65. When I got to the EA charger, the truck's "This Trip" display showed I had covered 26.3 miles at 0.8 mi/kWh and my remain range was only 55 miles! The charge display on the big screen showed my SOC to be 55%.
I was running ABRP to collect data using a BT dongle and those results show I drove 27 miles and my SOC went from 79 to 55.5. I calculate that to be 30.785 kWh used for the trip at a rate of 0.877 mi/kWh.
So, I decided to try charging to 90%, with the option of stopping early is some showed up and all the other stall were taken. I'm planning to drive up to Canada in a few weeks (without the trailer!) and there's a long stretch of I95 without a charger capable of 150kW between Portland, ME and the Canadian border. I wanted to know what's a feasible SOC I could reach beyond 80% in a resonable amount of time.
I didn't do a good job at keeping ABRP logging during the charging sessions so I didn't get good charging curve data. I was plugged intio a 150kW charger and it seemed to peek at around 135ish kW at first. The few data points I have are:
3 minutes in, 61% SOC, 134kW
38 minutes, 87% SOC, 20kW
53 minutes, 89% SOC, 7kw
When the power dropped lower than what I can provide at home using my L2 charger, I called it quits.
Summary from the charging station:
Total energy delivered 46.9779 kWh
End state of charge 89%
Charging time 54 min
Charging cost $0.00 + $0.32/min
Session fee $0.00
Charging $17.28
I have plug and charge setup and it worked fine. I did get a message in FordPass that my charging bundle reduced by 46.0 kWh.
On my return trip to Epping, I decided to try 60 mph instead of 65. The results were 0.9 mi/kWh over 25.8 miles.
Data collected with ABRP shows the SOC going from 90.0 to 69.5 so 26.855 kWh used at a rate of 0.968 mi/kWh.
Conclusions?
- Trip to Canada (New Brunswick) is not feasible (now) in a day if I bring the camper. Probably doable with lots of long charging stops at 50kW chargers if I also stop overnight around Bangor and charge at the campground using the 50 amp plug.
- If I want to achieve 1 mi/kWh, I'll probably have to drop my speed to 55 mph, or just stay off the highways.
- A 90% SOC is probably a bit too ambitious of a target to reach at DCFCs if I want to reach my destination in a reasonable amount of time. Maybe 85% and a slight drop in my cruise control setting would make more sense.
Could you possibly drive to a 50 amp charger and plug in, crawl back in your camper and go to sleep and continue your trip in the morning. Get your battery down around 25% and wake up with 100. I often drive my RV about four or five hours after work and then crawl in the back and go to sleep When I take my trips to my family‘s home state of Florida. I would probably be just laying around watching TV the night before anyway. So driving three or 45 hours makes my next day much shorter. It’s about an 11 hour trip total.
I’m willing to bet that after 2-1/2 years he figured it out.
