Need a Level 1 and 2 Mobile charger
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Hi all
My XLT ER is coming this Spring and I have a camping trip planned soon after.
I will need a mobile charger (didnt order the Ford one) so that I can Level 1 charge for several days via the campsites TT-30 connection (30a 120v)..i would like to get 16amps or so from this plug...I guess with a Nema 14-50 to TT-30 adapter?
Or there is a regular 15amp plug as well..
Also it would be good if the charger could also do level 2 Nema 14-50 for normal Level 2...
I see several on Amazon but almost always reviews say " this one didnt work for 110" or "voltage adjustments didnt work"
Anyone have one that works well for both Level 1 and 2 with amp adjustments and waterproof?
Thanks for looking
Pod
2023 AMB Lightning XLT SR
AMPRoad iFlow P9 is your jam….adjustable Amperage
Get a TT-30ev adapter and a 110 adapter. Love this set-up. Can deal with almost anything. Camped across TN and VA with this, love it WAY more than cheap Ford mobile unit.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
That looks like a winner! Thanks!
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
Would this work for the TT-30EV adapter?
I will get the AMProad 110 adapter for sure.
Parkworld 885378 EV Adapter Cord NEMA TT-30P to 14-50R (ONLY for EV or Tesla use, NOT for RV ) (1.5FT) https://a.co/d/9iIbkeg
12amps level 1.
Pod
TT-30 wired for EV works fine for 30amp Rv hookup with this rig. Plus the AMPRoad has a closed loop Wi-Fi so you can check specific charging details. I like that.
A couple points -
I don’t think the AmpRoad is UL listed, if that matters to you.
Don't bother with a TT-30 adapter unless you need to charge a non-Ford at L1. Get a lower-cost 5-15 adapter. Standard RV pedestals have both TT-30 and 5-15.
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
A couple points -
Yeah, I would like UL certified but not a huge deal. And correct I can just use the 5-15 and leave the trailer connected to the TT-30, that makes sense. Thanks, that saves $.
Fastnf
CALIFORNIA
2023 F150 lightning
Madasahatter1138
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
HaroldCal
Harold
Las Vegas, NV
Pod
Love the J+Boost as it is indestructible but the cost just a bit much IMO
