astricklin
99 Mercury mountaineer
@OutofSpecKyle
I would love to see a comparison between the two vehicles towing a regular size camper trailer, something like a 20-25 foot jayco or similar. Not an airstream or a teardrop or anything uncommon, just the standard boxy camper trailer you get at the local RV outlet.
If there's any way you can get your hands on one this would be great!
GoodSam
Good
occupying space
More questions:
-Any way to have the 360 set of cameras recorded?
-What is the security system on the Lightning?
-How well does non-BlueCruise Co-Pilot Assist hold curves? poorly marked roads? What is max curve angle vs. speed that lane keeping will work?
-What happens if a child’s hand gets in the way on the Frunk closing?
-What is the maximum scale weight (the regular F-150 manuals shows 1,400)? How accurate?
-Will Ford promise to have replacement batteries for the 2022 Lightnings that will have better range by 2030? You know, sustainability!
—What is Ford doing to insure Direct Current Fast Charge stations are everywhere (National Forests to Inner Cities) and include amenities like bathrooms and trash cans at a minimum? And that trucks with trailers can access charging equipment! Need pull through stations!
–What is the maximum height of standing water that can be driven through?
–Where are the fuse box and 12Vdc battery located? Can 12Vdc accessories be added?
–Driving over dry grass, is there anything hot enough to worry about starting a fire?
–Could fixed hood antenna be replaced with a power antenna that can recess when vehicle is off?
-Can the display show where the power is being used in the truck, that is, for seat heating, lights, front/rear motors, etc? Kia has this in the EV6, I think.
–How about having a heads up display like the Kia EV6?
-“Frequent use of DC charging could result in reducing your battery’s efficiency and lifespan. This is more pronounced on the standard range battery pack versus the extended range battery pack." What does "frequent use" mean? How many times, in what time period, will cause degradation of the standard range battery vs. times/time period for the extended range battery?
Farmford42
WA
69 Bronco
Farmer
Can most of the noises be turned off easily, door open power on kind of thing
put a full ibc tote in the back and drive it hard. Water movement will be interesting
can you tune the one pedal/ regen settings in any way
when towing does regen turn on trailer brake or does it try to use charging first
How long does a 20% to 80% charge take using the portable charger at 220 vac while waiting for the charge station pro
Can I charge tools in the frunk while it’s charging with power off.
What happens if you overload the bed weight for some reason, and the trailer weight.
low speed low traction like sheet ice on a hill. Does that confuse the traction brain.
