- First Name
- Adam
- Feb 15, 2022
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Occupation
- Drug Dealer of the LED World
The new Putco Freedom Blade 60" Tailgate Light Bar is now available for the F-150 Lightning from us!
https://www.4x4truckleds.com/putco-...th-plug-n-play-connector-for-2021-ford-f-150/
NEW Features exclusive to the FREEDOM BLADE – The Most Advanced LED Tailgate Light Bar Ever Made.
Give your truck the ultimate upgrade in lighting technology with the Putco Freedom Blade. This high-power LED light bar is designed and manufactured in the USA. Each light bar is designed to work perfectly with the year, make, and model of your truck. Unlike other rear light bars, the Freedom Blade is fully encapsulated in tinted polycarbonate resin that keeps moisture, dirt, and dust out ensuring a long life. Also, the polycarbonate makes the blade flexible so it forms to the lines of your truck, unlike other light bars on the market.
Putco Freedom Blade is named this not just because it was made in the USA but also because you can choose your turn signal color between Amber or Red. In addition, the Freedom Blade has an industry-exclusive startup sequence and scanning turn signal. Depending on your make and model this is available in two sizes 60″ and 48″. Each light bar is manufactured with up to 1,296 LEDs (60″version) rated at 60 Watts of power running at 2,000 Hz, producing a solid beam of light that is visible miles away!
If you are looking for an American-made tailgate light bar then the Freedom Blade is for you. This blade installation and setup only takes about 30 minutes with no cutting or splicing of wires. Each blade is compliant with the SAE 2022 IRSE19 DOT Compliant.
Available Here: https://www.4x4truckleds.com/putco-...th-plug-n-play-connector-for-2021-ford-f-150/
- Industry-Exclusive Start-up Sequence: You have the Freedom to choose your start-up sequence providing a beautiful approach light when you unlock or start up your truck.
- Light Output Colors: Freedom Blade has red, amber, and white LEDs – but you have the Freedom to choose between an amber or red turn signal!
- Scanning Light Bar: Choose between the standard flash or other fully sequential turn signals styles.
- Scanning Hazards: Center-out Scanning directional lights.
- Tripple Flash Brake: BE SAFE, BE SEEN with our Quick Pulse Brake Light Flash when you step on the Brake.
- Bright White Reverse Light: Produces a 6,000K cool white reverse light adding an extremely bright backup light at night pushing 3,000 Lumens.
- High Power LEDs: Including over 1,296 LEDs in a single 60″ light bar.
- Most Advanced LED Tailgate Light Bar Ever Made: 10 years ahead in technology vs any competitor!
- Made in the USA: Designed, manufactured, and assembled by Putco in Des Moines, IA.
- Patented: Exclusive design and functions by Putco Inc.
- Optional Lengths: The Freedom Blade is offered 48″ & 60″ with more sizes coming soon!
- Multi-Function Lights: The Blade light bar syncs with your tail lights adding additional running lights, brake lights, reverse lights, hazard lights & turn signals.
- Durable Housing: The LEDs are fully encapsulated in a tinted polycarbonate resin that provides top-notch weatherproofing from water, debris, and dust.
- Direct Fit Harness Included: Plug-N-Play with Putco’s Exclusives Quick Connect harnesses for today’s high-tech truck electrical systems.
- DOT/SAE: SAE 2022 IRSE19 DOT Compliant
- Warranty: Putco’s 3-Year Warranty on Blade™ Products.
