Radio Settings
Rip
Rip
2024 Lightning Platinum
Quality Consultant
So, when I tap the radio button, I get a screen with a bunch of pre-selected channels. How do I re-populate that screen with channels I actually want? Is there a way?
mrau
23 Lariat⚡ER
Tune radio to the station you want. Then press and hold one of their pre-selected buttons. It should change to your station.
Repeat for the other station/buttons.
The manual tells you this too.
Rip
Rip
Quality Consultant
I'll try that, thanks.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
My radio presets frequently change themselves. It's not all of them, but most of them. I suspect it is an issue with the software updates.
How common is this issue?
asten
Al
Missouri
F-150 Lightning
I had the same problem but turned out that the driver profile kept changing back to the default. Not sure if that helps you but could be your issue.
99.98% certain that's the issue, on the occasions I've seen a change of stored radio presets, it's because of default profile, I notice my avatar hasn't loaded in the upper right corner as a secondary clue, so I tap my #1 seat preset's button associated to my primary FOB/PAAK configuration, then the presets are corrected.
I've noticed at times that a remote start would switch to the default profile.
Too bad we can't slide the tiles around, to reorganize them, like on a phone. @Ford Motor Company
You can play Whack-A-Mole. Press the preset you want to move and then press and hold the button you want to copy it to. This copies it to that button. If that button is a preset you want, then first copy it to an unused button. Rinse and repeat.
DoyouLightning
BK
Charlotte NC
23' lariat ER
Every time I remote start with PAAK it reverts to the default settings. But a simple push of the driver saved profile and I'm back in business.
You would think the PAAK should have a way to note your the driver and keep your profile vs switching to default.
I personally hate when the steering wheel and seat move all the way back for easier ingress and outgress. I turned that setting off. But thats usually my quick indicator the truck is back to default profile.
Once I turned the easy entry function off it has never run, but maybe I changed it to off under the default profile as well, give that a shot.
