Shifter: suddenly has two “extra” detents
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
So, I’m doing some low speed parking and departing today and I keep putting the truck in the wrong gear. I figure I’ve just forgotten how to drive this very day. When I’m back safely in my drive way I test it. Sure enough, pulling from P to R the shifter has a detent and is still in P. Same thing at the bottom when I go from D to N. Already made appt. at dealership.
“I’m an excellent driver.” Rainman
The shifter in our trucks is one of the most unnecessarily complex designs in automotive history. It’s a huge mechanical contraption that needs a motor to function when all it needs to be is a simple electrical switch.
BuzzLightning2023
BuzzLightning2023
Los Angeles
Agreed. I won’t drive it until it’s fixed. I don’t want it to get into my head that I might or might not be in the right gear…
Adventureboy
I had this happen a couple of times in 2 years. I found folding the handle, turning the truck off, back on then unfolding it straightened it out. It seems to loose its detent locations once in a while and needs to reset itself.
MTcowpoke
Bill
Montana
Many diesels and a Lightning
Rancher
As @Adventureboy says, fold your shifter down and back up, should straighten out. I've messed mine up numerous times chasing cattle when I slam shift between forward and reverse. My guess is a stepper motor gets out of sync.
Whammy Bar
1971 F100 + 2022⚡Lariat ER
You should just stick to high speed parking like the rest of us....
BuzzLightning2023
BuzzLightning2023
Los Angeles
I appreciate that! I won’t try it until I make the dealer try to fix it. It’s a real safety issue and I want to make sure it goes on its permanent record to secure my warranty rights.
Adventureboy
Agree, it is quite annoying and dangerous when things don't line up on the shifter. Wouldn't surprise me if there is a recall on this one at some point.
rdr854
Northern Virginia
18 Volvo V90, 22 Ford F150 Lightning, 23 Outback
This is a known problem. My shifter assembly was replaced under warranty.
