Speed governor
4seaer
Steven
2024 ford f150 lightning
Does anybody know if it’s possible to take off the speed governor?
ZheWiz
Jack
Central NY
2023 F150 Lariat ER. Less Tech than CT 😘
Database developer
Not so far. Closest I’ve seen is lying to the truck about tire size using Forscan. If you tell it the wheels are smaller than they really are, you’ll be going faster than the truck thinks. Of course the speedo and odometer will be off too. And I assume there’s a limit to how low you can go. I read somewhere someone did that at the track and gained a couple MPH. Don’t know details though.
theawesomegamer
Alton
Utah
2023 F150 Lightning Lariat ER w/ Max Tow
I'd have to look-- but I'd think it's probably something to do with the tires. I'm not sure through. You can definitely feel it slow down when you hit the limiter.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
I too have much interest in this topic lol
Love the Lightning, but the fact that my VFR750 has a higher top speed…
When I have the "need for Speed" my 2012 ZX14r does the trick
Firn
23 Pro ER
You all are going to make me miss my snowmobiling days. Nothing like bombing across a lake at a buck fifteen, in the dark and blowing snow, and have a fishhouse suddenly flash by....
There is a FORSCAN setting related to Police use that says "max speed". I dont believe it will have any effect on our trucks but might be worth a try.
Ted23Lightning
Ted
I’ll have to test this… in Mexico or Canada 😏
theawesomegamer
Alton
Utah
I just checked the tires on my Lariat ER on stock wheels and the speed rating is T. That’s 118mph/190kph. So the tires are good up until then.
