Unused 50 Amp breaker going to old 3 prong dryer plug - swap with NEMA 14-50 outlet?
TheBertShow
Bert
South Georgia
2021 F150 KR PB
Getting my '23 Lightning today. Beyond excited, but a little inexperienced in electrical work...
Being a 23 it comes with the Ford Charge Station Pro of course, but with the mobile power cord, I need to have something more efficient than a 120v plug with the mobile power cord until the FCSP arrives.
I have an older 3 prong dryer plug outlet in my garage where the washer/dryer when my house was first built in the 80's. Previous owners added on to the house (with a new electrical panel separate from the original one), and washer/dryer is now in the added-on part of the house. There is a 50 amp breaker in the original panel, and I'm almost certain that the 3 prong outlet is connected to this breaker.
I am going to have an electrician come look at it, but if I'm correct that the 50 amp breaker is connected to the 3 prong outlet, is it a simple swap-out and plug-and-play for a 14-50 outlet?
mrau
Lariat⚡ER, VW ID4
Likely the 3 prong outlet does not have a neutral wire running to it. Not really a problem since an EVSE does not use the neutral wire. If the wire and breaker are both rated for 50 amp, then a 6-50 outlet could be easily installed in place of the dryer outlet. The 6-50 is like the 14-50 only it has 3 prongs instead of 4.
Some folks have used a 14-50 on a 3 wire circuit and then label the outlet with "No Neutral Wire". Likely not code but should work fine.
Scrappy
Jeff
Chandler, Arizona
2023 Ford F150 Lightning ER Lariat
Electrical Engineer
If your wiring is 6 AWG you may want to consider doing a direct wire to your FCSP. You might even be able to bump up the breaker to 60 amps and charge at 48 amps (20% faster).
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Depending on your level of patience, you could consider a 16-20 amp charger that uses the old 3-prong connector as a temporary solution. When I visit family who live about 70% charge away from my home, I plug into their NEMA 10-30 dryer socket with a cheapo 16 amp charging cable. Takes nearly all day and night to charge back up (about 19-20 hours), but it does the job.
Have electrician detrmine what wire you have and whether its NM-B (aka Romex) or individual wires in conduit (probably Romex). Then you know the max breaker size (see this chart). If Romex #6 you can't put in a 60A breaker, it's only good for 55A.
Then hard wire the FCSP. Set the dial based on breaker size x 0.8 (e.g. 60A breaker =48A charge setting, 50A breaker=40A charge setting):
Ford F-150 Lightning Unused 50 Amp breaker going to old 3 prong dryer plug - swap with NEMA 14-50 outlet? 1727827348058-m5
