Status
Not open for further replies.
astricklin
99 Mercury mountaineer
No, that isn't true. While the base chemistry for the cells (tech) is roughly the same (Ford uses different ratios), the Lighting cells are made by SKI and the Bolt was made by LG.
The issue with the bolt wasn't with the battery chemistry, but the physical assembly.
luebri
Neenah, WI
From: Feb 15, 2023 3:00 PM ET | Ford Motor Company (F) | Clark Schultz, Seeking Alpha News Editor
Ford extends F-150 Lightning production halt through the end of next week
"Ford Motor (NYSE:F) confirmed on Wednesday that it is suspending production at the Rouge Electric Vehicle Center through at least the end of next week.
A statement from the automaker indicated that during a standard Lightning pre-delivery quality inspection, one vehicle displayed a battery issue.
"We believe we have identified the root cause of this issue. By the end of next week, we expect to conclude our investigation and apply what we learn to the truck’s battery production process; this could take a few weeks. We will continue holding already-produced vehicles while we work through engineering and process updates. We are not aware of any incidents of this issue in the field and do not believe F-150 Lightnings already in customers’ hands are affected by this issue."
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
I seem to recall a production issue with the Mach E that resulted in a stop ship notice. It also was found during a Quality Inspection at the end of the production line. In the end it turned out to be some bolts that weren't properly torqued by recent hires. I could be fuzzy on the exact details, but before expecting a new Lightning battery or losing any sleep, I'll give Ford some time to figure out the cause and implement a solution.
greenne
Nathan
Niskayuna, NY
" A statement from the automaker indicated that during a standard Lightning pre-delivery quality inspection, one vehicle displayed a battery issue. "
My thoughts are Ford is being really cautious and prudent here. They know they cannot afford to screw up the reputation of the f150. My guess is they are going to take every potential problem(no matter how small) seriously...
Ford cannot afford to have a Bolt type incident tarnish the f150 name....
SilverBrewer
Beau
Cincinnati, OH
2021 F150 Platinum Powerboost
Or the old cruise control debacle. . .
MAhauler
Boston
Ford Explorer
Ford has issued a statement today and it looks like it could be a few weeks:
“During a standard Lightning pre-delivery quality inspection, one vehicle displayed a battery issue. We believe we have identified the root cause of this issue. By the end of next week, we expect to conclude our investigation and apply what we learn to the truck’s battery production process; this could take a few weeks. We will continue holding already-produced vehicles while we work through engineering and process updates.”
“We are not aware of any incidents of this issue in the field and do not believe F-150 Lightnings already in customers’ hands are affected by this issue.”
“We will continue to update this story as more information becomes available,” Ford said.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
That statement taken on its face suggests this is a different issue from the module issue being discussed elsewhere in forum (and that I am experiencing).
with a single vehicle causing them to pause production and shipment, it suggests the issue was mission-critical/dangerous.
the separate module issue, on the other hand, is being handled somewhat casually on the down-low, with lots more than one vehicle implicated.
Reactions: GDN
jlwillia6
‘14 Silverado, ‘23 Lightning Lariat ER (ordered)
Can you summarize the module issue for those of us out of the loop?
erock
E
arkansas
2021 F150 Platinum, 2022 Expedition Limited
It was probably mine, which is currently sitting on the ramp after being built, but not set for shipping.... sorry guys.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
Keep in mind, the batteries are not manufactured in the final assembly factory.
If they stop the production line they either want to test the most recent battery shipments or change the way they're installing them to ensure whatever went wrong with that one vehicle doesn't happen again.
Toyota pioneered a policy of stopping entire production lines to diagnose or eliminate problems decades ago and it's now standard operating procedure in most factories. They even stop for small problems. Although they lose a lot of time, it's still better than trying to diagnose and recall countless vehicles that are produced with the same defect.
It could simply be batch of some tiny part that cracks or doesn't quite fit as it should. Once they identify it, they re-order or re-design the part or change the installation procedure and they have fewer vehicles to recall later.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
EEK!
Don't say that - my MME is somewhere in Mexico waiting for 8 weeks.
Maxx
If it does not set my house on fire, I am not worried. However, I wonder if this issue has impact on the longevity of the battery performance of trucks already on the road, and it takes the battery down to 70% instead of 80% at eight years, would we ever know? In fact is there a battery life meter on the interface available to the owner that you could use to take it for a service if it goes under 70% during the warranty? If not, what does that warranty mean anyway?
Blainestang
FL
F56, R55, Pro
The article is weirdly written. It implies there was a fire because they say they reported a fire in a previous article, but then the link to that article is dead.
And a fire definitely isn't the same as "identified the issue on a Lightning unit during a standard pre-delivery quality inspection."
Personally, I'm waiting to hear some more confirmation before believing the two incidents (fire and battery issue) are the same incident.
Status
