USB charger - low power output?
Akemisdad
Dan
San Francisco
F150 Lightning Platinum
Anyone experience that the usb slots in the front tray don’t put out a lot of power? I plugged my phone in and had it charging while it was driving. It showed power was coming through but the battery % on my phone didn’t increase. Not by a single %. anyone experience this?
Formerly
NY
Ford Lightning 2022
Construction Estimation
Was you phone dishing out carplay or Android auto? Gps is a major power user, so the charging offsets its draw
Adventureboy
I use Carplay all the time and my phone (iPhone 14 Pro Max) charges fine when in full use and plugged in as did my previous iPhone 11 and my wife's phone. It usually only takes an hour or so to fully charge. I would suggest first trying a replacement cable and see if that helps. 2nd, try a friend's phone and see if it charges. That should help rule out a power problem from the USB port.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
if you use the USB C port, it has much more power, like 3x the power of the regular USB port.
you can buy an adapter on amazon for less than $5, or a new cable that is USB C.
jefrank
Jeff
Fenton, Michigan
2022 Ford F-150 Lightning Lariat, 2004 BMW 330Ci
No issues with the USB-C port on my Android running Android Auto and Spotify full time. Phone definitely charges while driving.
Yellow Buddy
Mid-Atlantic
Smart Ass
The USB only puts out enough to maintain the phone if you’re using it to do CarPlay, stream audio, GPS, etc.
If you plug it into the USB C it’ll full charge without any issues.
davehu
hot springs, AR
USB c only works if your phone supports usb c. let me clarify, it will work but my understanding is that the power supplied won't be any different than a standard USB. The phone has to have a USB C input.
