Will max towing option improve Lightning's range?
ExCivilian
'22 Lariat ER, '22 Platinum
Professor
Extra cooling impacting charge rage does relate to charging heavier loads because...remember the range we'll have with an 8K tow load.
Texas Dan
Daniel
I’m still not convinced that the max towing package doesn’t impact range. The Platinum trim package has a range of 300 miles with ER battery compared to the 320 mile range of all the of the other trims with ER. One of the main differences between the Platinum and all the other trims is that the Platinum trim comes with max towing as standard.
The ICE max tow packages come with taller gearing that definitely reduces gas mileage. I don’t think the 150L with max towing has taller gears but pushing around all that extra cooling fluid could reduce range. I’m considering trims other than the Platinum because I want to maximize range but I may have to go without max towing if we find out that option reduces range.
beatle
Springfield, VA
It's the 22" wheels of the Platinum that cut into range, not the towing package. Max tow only increases cooling capacity. Coolant pumps do use energy, but nowhere near enough to affect range. That is if it even increases power draw at all. The Lariat ER + max tow window sticker showed 320 miles of range, and the Lariat has 20" wheels.
If you care about range, buy small wheels, avoid A/T tires, install a tonneau cover and (maybe) opt for powered running boards.
SeanOC
SeanOC
LINY
ā€˜18 Raptor ā€˜21 Tesla Model Y
Pilot
AFAIK power running boards is not an option, (it wasn’t on my Lariat ER) and tonneau covers have been tested to not improve fuel economy on pickup trucks.
PungoteagueDave
You can now add power running boards as an option on the Lightning. I had my dealer do it last week. This may delay delivery.
Fordskeptic
Chevy
631Belle#
Chevy, toyota, honda, jeep
If I ever get invited to order the Pro I'd select max tow. My thinking may be off, but here it is:
-My occasional (local) towing is close to the 5,000 pound max (and what if I get a bigger boat?)
-Max Towing doesn't cost much and probably adds to resale value if/when that time comes.
-It is now or never...there is no dealer installed or aftermarket max tow option (better be safe than sorry)
-It may help with charging and/or battery longevity and does not seem to add appreciably to weight/drag/etc. and/or introduce additional high maintenance components (so no real downside other than initial cost)
