Lightning Rod
- Nov 27, 2022
- North Coast
- 2023 Ford Lightning Lariat ER
- Occupation
- CNC PROGRAMMER/MACHINIST
On my truck I just leave the truck "ON" and consider that Dog Mode, Keep-AC ON mode and Sentry Mode...
Leaving the truck fully ON with the AC set at a comfortable temp, exit and lock the truck. If there is no key present in the vehicle I will not shift out of Park (in case someone broke in). All other systems remain on and the motion alarm is off.
If you will be gone for more than 30 min hit "Settings -> Vehicle" and flip off the "Vehicle Timeout" switch to remain on past 30 min. The 30 min timeout reactivates with each key cycle. You can set the timeout to remember the last setting with ForScan if you prefer it not reset and remain off all the time.
I installed one of those exact fit dash cams with front and rear cameras. it's powered off the review mirror so as long as the truck is ON it's taping.
I shut off AC and put the screen in quiet mode, lights to "OFF" if I just want "Sentry Mode" and no Dog or Keep..
99% of the time I find the Ford way smoother than Tesla's mode approach. I'm usually out running errands with the kids or the pup or both. I just get out and lock the truck, no extra mode to press or think about.
Yes, I do the same thing. I have a screen saved on SKETCH app and it says, "The heat is on, my dog is fine."
I bypass the countdown timer even if I'm going to be gone less than 30 minutes.
The rumor was, Ford was going to add a Pet Mode but I'm not holding my breath lol.
