XLT OEM Bed Lights Install
Blochead21
PA
Black 22 XLT 311pkg
It didn’t work. Just the graphics showed up but didn’t function.
jimfigler
Orchard park, NY
if i install the lights without using Forscan, will they just not work at all? looking now into how to use forscan... but was curious if they just wouldnt work at all without it.
I was concerned about using Forscan but is very easy. Watch a few videos on youtube for basic usage and then follow blocheads changes and you will be fine
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
Yeah, following OP instructions including Forscan changes should work. Forscan can also be weird sometimes, sometimes you need to cycle power via ignition and even drive the truck before all options take.
I have a pro without zone lighting (actually, I don’t have any options!) and I haven’t been able to get them to work. I followed the OP instructions. Admittedly, I haven’t poked around in FORScan to see if there’s anything obvious my zero option truck needs to enable to get them to start working.
So did you find the solution here? I am having the same issue as you where Forscan says complete but bed lights don’t turn on.
Blochead21
PA
Black 22 XLT 311pkg
This will work if you enable the correct options in Forscan. If it doesn’t work try it again and cycle on/off the truck a few times. If needed you can force reset the module through Forscan but it shouldn’t be needed.
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
Tried enabling correct options in Forscan again and turned on and off a few times but still no luck. Do you have any suggestions?
Blochead21
PA
Black 22 XLT 311pkg
Maybe give it a day or two to take effect.
Pennsylvania
2022 Lightning Pro
It’s been weeks for me. They don’t work. I even ordered another switch and lamp to ply with on the bench so that I could understand the logic completely before digging in to the plugs to see if I could figure out if it was something I did during install. But the parts are on back order so I have t done any more.
Forscan shows the OP’s suggested options as active. Nothing doing.
LightningProAval
Paul
New Jersey
F-150 Lightning Pro
My hunch is that another option needs to be activated in FORScan for us Pro owners. Mine is not working after a couple of days and I also reset the module
BennyTheBeaver
2023 Lightning XLT ER
I followed the OP instructions exactly and have had no issues on my MY23 Pro with Tow Tech.
jimfigler
Orchard park, NY
Yep mine still works too. I bought the crazy color changing led set them to blue like the truck.
Benny have tried anything with the door keypad yet? I’m debating on just cutting the trim to accept the keypad or buying the pre-cut trim. But I want to make sure the wiring is in the door.
BennyTheBeaver
I haven't yet, I personally would buy the precut trim. Unfortunately I still can't find an in stock keypad...
BennyTheBeaver
Reactions: s_c
jimfigler
Orchard park, NY
Yeah, I bought from there and 3 others. They all cancel the order within a day due to it being out of stock.
More money but shows in stock.
Driver Side Keyless Entry Keypad | Replacement for 2015-2020 Ford F-150/250/350/450/550 Super Duty | Replaces# 601-046, FL3Z14A626AA https://a.co/d/gsPUomT
