cybertruck
Anthony
Wichita, Kansas
F-150 Lightning
I leveled my truck with rough country 2” kit and bought some ford takeoffs. The range did take a hit in getting 1.3- 1.4mi/kWh vs 1.5mi/kWh @ 38F + 75MPG
I was too scared to go 35s but these are 34.8 I believe and I still have some clearance no rubbing under any conditions. Bumps, off road, steering end to end are all still good. Tires are a bit noisy but that’s expected.
Ford F-150 Lightning 2" level kit and 295/70R18 tires installed on Lightning Lariat ER 7DAD7721-BB92-4CEE-9614-239E6AEB2C52
Ford F-150 Lightning 2" level kit and 295/70R18 tires installed on Lightning Lariat ER 9A5BF42D-CDBE-45FF-B90A-C0A03AB0451D
Ford F-150 Lightning 2" level kit and 295/70R18 tires installed on Lightning Lariat ER 2CBDB6CB-8798-491F-B988-63427E0B78F6
Looks great! I'm not a lifted truck fan but yours really looks OEM, which I like.
How far off is your speedometer?
eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
looks really nice! But I thought you were looking to sell. Greeting from Lawrence!
eRockBoon
Erik
Kansas
His are also a bit shorter than a normal 35” tire and more importantly almost 1” narrower.
Shigoku
Austin
Tumwater, WA
2020 F-150 Lariat, 2022 Lighting Lariat ER
Shellfish
Did you change out anything on the shocks? or just add the rubber lifts? Which 2-inch rough country lift did you purchase? I want to make sure I get the right one. Thanks!!
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
You can change the tire size in Forscan if you use it. Then it will be exact. I’m doing the same lift and put larger tires and well - should have it back next week! The tires are already on but waiting for the lift…
Ford F-150 Lightning 2" level kit and 295/70R18 tires installed on Lightning Lariat ER DA46F204-3AF8-48A4-A671-CCC32A43135A
