Factory Wheels with Aftermarket Tire Thread
jwgreene
James
Chattanooga, TN
2021 F-150 XLT supercrew in leadfoot with 5.0
Apologies if you already posted them, but do have pictures from the front. I am thinking of the exact same set up. Thank you in advance.
This is all I have, but I’ll try to get out today to take some from the front.
Captain
Ryan
Washington
2021 F-150 XLT 5.0
I don’t recall seeing any when I went through this thread……..is anyone running 33x12.50r18 on the stock wheels?
PBXL
2021 F150 XL
For the three XL owners out there:
285/70R17 Nitto Terra Grapplers G2 on the stock 17 inch alloy rims fit great and no rubbing as far as I can tell:
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread IMG_20211008_111628630_HDR
Mkaytor
2021 f150
has anyone tried a 305 65 18 on the 21 sport wheel yet?
F150XL
2021 F150 XL CCLB 4WD
I am one of the three. Do you think 285/75R17 would fit stock? Thanks.
PBXL
2021 F150 XL
285/75R17 would be 33.8". That would be pretty close without some sort of front lift or level in my opinion. The only other people running 17 inch wheels are people running Raptor wheels so they may have better first hand experience.
F150XL
Thank you for the feedback. I know I have seen a few owners fit the 285/75R17 on the previous generation using stock wheels without a level kit installed, so I was hopeful the newest generation would be the same. I believe the raptor wheels are a different width and offset from my steel wheels. I may just give it a go and if they fit, great, if they don't, I will install a $100 puck lift and roll with it. Not a huge deal either way. The front is super low on my truck anyways even with a loaded contractor shell on the back.
RCR001
Just North of the USA
2021 F-150
Mounted THE 295 70 18 tires on the factory rims today, Went with the Bridgestone Dueler A/T Revo, Not a whole lot of room to spare but there is no Rubbing, tire shop figured they would, But thanks to all the info here, I was confident they would be fine! Thanks for helping me spend my Money!!
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 20211019_120346
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Should fit no problem. Some people have been able to fit 295/70R18 on the stock wheels which is a 34.3 and a bit wider than the 285/75R17 with no lift and no rub. These new f150s are impressive with how big of a wheel tire combo you can fit on it stock.
slatelacy
Slate
2021 F150 Platinum Powerboost
Whats the general consensus on the largest BFG KO2 on 20inch stock Platinum?
NiftyF150
Tony
2021 F150 XLT Sport Leadfoot Gray 302a Ecoboost
Maintenance Supervisor
Mounted up a set of 35x12.50 Toyo Open Country AT III on the stock 18's. Very impressed with how they ride. Much better than my Nitto's ride. Of course it's a D rated tire vs's Nitto's E load.
I apologize these are not the best pics, truck is dirty.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread IMG_6727
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread IMG_6724
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread IMG_6726
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread IMG_6730
Liquid-Todd_AZ
Todd
Arizona
Acura
Sales
Here is a pic of 295/70-18’s and 0 offset rims, they fit great! Only had to trim the fairing about a 1/2”. Better proportion in my opinion than the 315’s (35’s) on 17’s like the raptor has.
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 043E630E-00B2-4183-A4D2-EBD80F7E8FC2
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 0B00602A-3ACB-4638-A667-C4C7CD8CCD8F
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 44E4B032-BD1C-4138-A034-ABFACA1F026E
b4hand
Austin TX
2021 Powerboost Carbonized Grey
Here is a pic of 295/70-18’s and 0 offset rims, they fit great! Only had to trim the fairing about a 1/2”. Better proportion in my opinion that the 315’s (35’s) on 17’s like the raptor has.
What lift kit is this?
Liquid-Todd_AZ
Todd
Arizona
Acura
Sales
MotoFab 2.5” level kit.
Changed rake from 3-1/4” to 3/4”.
Nothing in rear. Very happy so far, had to adjust headlights and get an alignment, but that’s it.
I had bilstein leveling shocks and 35’s on my 2013 FX4 so I kinda had a set up in mind!
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread 5EBA8ECA-4E50-446A-BB96-B516A1B42BE8
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread AFAF765C-67CF-414E-AFA7-3E015B3BD0DC
Ford F-150 Lightning Factory Wheels with Aftermarket Tire Thread C166B24A-64CE-4E9D-B152-516B1EAD41B8
dannko58
Dan
New Braunfels TX
2021 F150 Lariat, Powerboost, Supercrew, FX4, 502A
Professional Bum
do you have a leveling kit?
