Anyone remove rear blocks?
KartRacer25
Richard
San Diego
2021 F-150 SuperCab Sport 4x4 5.0 3.73 Space White
Senior Software Engineer
Wondering if anyone has tried removing these on a 2021 yet, and if there's any issues? Does the 2WD not come with these 1" blocks? I was thinking of removing them and adding Fox 2.0, set to 1" to retain 1" of rake and improve handling. My 4x4 Sport w/o FX4 has 3" of rake stock.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Not, yet. But I plan try it soon. I'll see how I like it, and put them back if the boat makes its squat too much for my liking. I just want to verify I have enough thread on the U-bolts. I can’t seem to find the oem 2wd ones anywhere...yet.
I believe only the 4wd has blocks, but there are 3 different blocks for the 4wd based on wheelbase and payload configuration.
Ford F-150 Lightning Anyone remove rear blocks? 033D4AA1-461D-4AD3-8E64-2129F8C7BEDA
Ford F-150 Lightning Anyone remove rear blocks? 99D37C38-C2BC-4451-8F96-A9E6A5C84A07
Ford F-150 Lightning Anyone remove rear blocks? 8F7CED12-07FC-4EC5-912C-53E1504AF757
KartRacer25
KartRacer25
Richard
San Diego
I saw another post for rear flip (drop )with block removal pic that had enough extra thread to do it, so should work. I hope. Let us know. :)
But thats one reason I'm wondering if 2 WD doesn't have it but uses same U bolt.
Didn't know there were other possible blocks. Seen all kinds of stacked add ons.
Was wondering if there is a min thinnest block that should be in there?
I believe people have just removed them on previous gens.
Zyvin
SC
All three of those blocks are 4wd only.
The 2wd doesn’t have blocks, that’s why some people on the old model would use the 2wd U-bolts, just because they wouldn’t hang down as much. Some others just cut off the excess for a cleaner look. The 21’s have a curved top U-bolt, and the old ones were square so they aren’t interchangeable. After looking at mine, it does look like there is plenty of thread there to pull the blocks and use the existing bolts.
Blockhead
Brad
Lombard Illinois
2021 F150 XLT 302A
Regional Manager
2WD U bolt part number is
ML3Z5705A
I just was at the dealer and confirmed the part number on 4 different 2WD F150s. All were SCREW models.
12Lariat21
2021 Lariat 502A
Engineering Manager
Just removed mine today.
Lariat 6.5' bed, Super Crew
Max Tow, 4x4
Took 1 inch out of the fender to tire gap, defiantly enough to take away the obvious rake of the truck, certainly not level, but I sure like it this way better.
Original U-bolts are just barely long enough, but they are long enough. I'd recommend installing some washer to keep from bottoming out the nuts, upon reinstall.
Ford F-150 Lightning Anyone remove rear blocks? 6F0255DB-2435-407B-8836-17ADD0E1CB38
Ford F-150 Lightning Anyone remove rear blocks? 2B518292-CF71-48BA-8263-518ECB515FA2
Ford F-150 Lightning Anyone remove rear blocks? 31DC3FEE-3AA6-4613-97B2-B2A280FE1046
Ford F-150 Lightning Anyone remove rear blocks? 4DDC2663-D3DA-412A-B179-440485EE7231
Ford F-150 Lightning Anyone remove rear blocks? A227868F-A6B4-4B8B-A892-034AC7FC8D06
Ford F-150 Lightning Anyone remove rear blocks? 5B4CC178-B3B6-4565-86F9-F8302F9A8D0B
Ford F-150 Lightning Anyone remove rear blocks? 446E9385-9986-40A7-AC38-63BC4709969A
SinCityF150
Las Vegas
2021 F150 Tremor
Max Tow, 4x4
would you be interested in selling me your old blocks. I have a Tremor which has 2” blocks and I want to drop the rear end 1” and lift the front 1.5”. My truck currently has a 4” rake. I figure if I lift the front 1.5” and drop the rear 1”c the weight transfer should level me out pretty good and leave me less than 1.5” rake that the math on paper says I’d have remaining.
do you have a pic of your U bolts after you removed the blocks so I can see how much thread you have hanging down?
Reactions: Doc
12Lariat21
2021 Lariat 502A
Engineering Manager
I don't think I'm ready to get rid of the blocks just yet, still trying to decide if I want to keep it lowered, or put them back in, and raise the front to 'level' it.
Spacers are Part No. 5598 MSRP$29.38 from my local dealer, if you want to just buy some from Ford.
U-Bolts are Part No. 5705 MSRP$32.50 (backordered...)
Ford F-150 Lightning Anyone remove rear blocks? f150_axel
SloSVO
Phoenix
2021 F!50
DId you buy new ones? Id consider selling mine.. I'm going to be taking them off in the next few days
Littlefield82
Holly Springs, NC
2021 Lariat 502a PB FX4 5.5'
Civil Engineer
What kind of deep socket did you use that is deep enough to put those nuts on?
Littlefield82
Holly Springs, NC
Civil Engineer
I tried this tonight. Got pretty far and realized my deep socket was not deep enough and had to put the blocks back in. Huuuge pain. Also realized my torque wrench maxes out at 80 ft lb.
12Lariat21
2021 Lariat 502A
Engineering Manager
I have a Craftsman set 1/2inch drive set that I used, had them for a long time, so I don't know if they are are extra deep, or something not 'normal'. I will say I first tried my impact sockets, but that socket was not deep enough. Another option would be a crows foot.
Ford F-150 Lightning Anyone remove rear blocks? 1638797223689
Sorry about your head aches with the process. You will likely want to just order the shorter U-bolts anyway, as these are barely threaded enough to accomplish this job. You need to be careful to tighten them evenly otherwise you'll just bottom out the nut where the treads end. I would highly recommend a thick washer or 2 under each nut to ensure good clamp load.
HDT05
2021 F150 Lariat FX4 5.0
Hi,
Since you removed the blocks, have you noticed any difference in the handling? Does it understeer less?
I would be interested to know if there is any difference on high speed curves?
Thanks
Littlefield82
Holly Springs, NC
Civil Engineer
I just got off the phone with my local Ford dealer and they quoted $35/per U-bolt for the 2 wheel drive ($140 total) and $8 for replacement nuts. If you have a 4x4 and want to ditch the longer bolts and use 2 wheel drive u bolts it's not a cheap mod. If you want to keep the longer 4x4 u bolts then make sure you have washers and a really long deep socket in order to tighten the nuts as there will be a lot of thread showing on the 4x4 u bolts.
brisch
Central OH
2009 F-150, 2022 XLT 302a SCAB
Haven't got the truck yet, but when I get it, was planning on removing the blocks and just cutting the threads down. So there's not so much hanging down. Still gonna put some washers on to tighten up good. Think that will work?
