Is there a Market for Lariat 20” wheels?
MannyFrescoSC
Manny
Fort Mill, SC
2018 Jeep Wrangler
I’m likely going to get a Lariat but will put 17” wheels with 33’s on. Anyone here want them and what would you offer?
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
There would be huge demand since the bolt pattern will fit the ICE F150 which there are many on the road.
I would put them on a marketplace (FB or eBay or OfferUp) online - it will sell for a good chunk of change to fund your 17".
As for 17" - is there a specific reason for that size w/ 33" tires ?
I opted for the (Pro or XLT) 18" wheels so that I can put on winter (snowflake on mountain) tires for when I take her up to the mountains for fall/winter steelhead fishing...
Of course, the winter tires will be the same OEM size.....
Sgt Beavis
Rick
Colorado
2021 Wrangler Rubicon and 2018 Mini Cooper S Count
overpaid computer nerd.
I"m guessing Manny is like me and wants more tire side wall for off roading or general ride comfort.
MannyFrescoSC
Manny
Fort Mill, SC
2018 Jeep Wrangler
Yup this and I like a slightly aggressive looking truck. Getting AT tires like KO2’s or something similar.
cts888
LA
Chevy Bolt, Ford Escape
I will definitely be looking for lariat rims to put on my Pro truck. Love the looks of them. Not sure what fair value would be though
Sgt Beavis
Rick
Colorado
Same here, but I'm going with Falken Wildpeaks.
Sgt Beavis
Rick
Colorado
This is another tire on my shortlist ?
I like it because it handles slightly better in snow but much better on wet pavement. I had K02s on my Raptor and it got a little tail happy when unloaded and wet. However that may not be the case with the Lightning, due to the added weight..
I'm still investigating ATs that give better range. So far the only AT I know of, for that, is the Pirelli Scorpions that Rivian is using. But it seems to be a bit more vulnerable with it's sidewalls. So I'm still researching it.
sotek2345
Engineering Manager
Just make sure you are planning on the range hit. I put KO2s on my 2016 and it was almost a 20% decrease in MPG on the highway vs. stock. If they picked lower rolling resistance stock tires on the Lightning (likely), you could be seeing a really big hit!
Pedaldude
Arizona
People are definitely buying used take-off wheels/tires but don't expect a lot, especially since the aero wheels on the Lightning aren't everyone's cup of tea.
The Pro is shipping with 18" wheels, the Lightning is a heavier truck than the other F-150s, so it's possible that they will be using larger diameter discs. Also, I can't remember seeing any wheel specs but the offsets might be different than the fossil fuel trucks.
As for swapping out wheels on BEVs:
The Lightning wheels appear to be aero wheels, prepare to lose some range if swapping them with aftermarket or factory ICE wheels. Here's an article where an E-Golf loses about 20% of its range after a tire swap:
https://www.roadandtrack.com/new-ca...stickier-tires-impact-an-electric-cars-range/
Cliffs notes version:
https://www.greencarreports.com/new...-can-have-a-huge-effect-on-electric-car-range
Swapping within the Lightning lineup should probably be fine. I also don't know if Ford has released the wheel specs yet, the offset could be different and from looking at pictures the bolt pattern looks the same but who knows.
The E-Golf example above is extreme, the aero wheels are supposed to add 1-2% to the efficiency of the vehicle and it looks like they're retained for the test, So it shows how much of a hit is possible not using low rolling resistance tires. How low rolling resistance the Lightning tires will be remains to be seen.
MannyFrescoSC
Manny
Fort Mill, SC
2018 Jeep Wrangler
Start a thread. I’m also doing similar research
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
I may be interested after I see what the wheel specs are if and when I get my truck. I use all season through most of the year. The winding hills and icy conditions of western PA require soft rubber snows and 4A common sense on pickups. But I’m guessing you’ll sell stock rims and tires as a set. That wouldn’t work for me.
Torch
Christian
Bend, OR
2021 F-150
If you are going with 17" rims make sure the fit on the rear of your truck. Gas trucks with max tow package have the larger rear brakes
Anyone know if 17” aftermarket rims will fit on a Powerboost?
astricklin
99 Mercury mountaineer
Good news is that with the batteries and the rear motor the lightning will have much more even weight distribution and should handle way better in the snow than a typical truck
