Sapphire
Chicago
2021 F-150 Powerboost Platinum
That's interesting... I bet it's because of the URL encoding when sending the data to ford for the token.
I might need to pre-escape the text
Probably needs Java escaping. Will was getting Error 500: java.lang.IllegalArgumentException back from the server, causing the widget script error. I had him test with raw curl commands to cut out the script as a factor. If I de-laze myself into changing my password to include % and $ and try putting \s in front of them, I could just test it myself. It might work. Haha. URL encoding would just put more %s in there (but, maybe it was the $ being rejected). Apologies for all the nerd talk for everyone reading this!
So it was the complicated password causing the issue that @WillB17 and I are having?
Not because it’s complicated, just because of the symbols. I’m using a complicated password too, but only letters and numbers.
Plattypuss
PA
2021 F150 Platinum PowerBoost Rapid red
Probably needs Java escaping. Will was getting Error 500: java.lang.IllegalArgumentException, causing the widget script error. If I de-laze myself into changing my password to include % and $ and try putting \s in front of them, I could just test it myself. It might work. Haha. URL encoding would just put more %s in there (but, maybe it was the $ being rejected).
Thanks for figuring it out!
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
It’s very possible. I will get you a version to test with asap.
Please bear with me. I have another update I'm working on releasing. I'm trying to roll all the fixes into my existing work.
I’m trying to also build a script whose sole purpose is to download and update the ford pass widget script. So no more copy-paste :)
Sapphire
Chicago
Ok, never mind, I had a dumb. @tonesto7 I just successfully tested it, you were right. The password needs to be URL encoded when you put it in the POST payload. (I didn't pay attention close enough that it does have the application/x-www-form-urlencoded in there). Just needs an encodeURI slapped in there.
Plattypuss
PA
My friend. I appreciate your efforts. No worries about me. I can change my password and if that doesn’t work I can wait longer.
Sapphire
Chicago
Well, if you want your symbols back (and for the others still having issues and also have ants in their pants waiting until @tonesto7 puts this into an upcoming version), replace line 1152 from the 1.1.1 version of the script with this:
req.body = encodeURI(`client_id=9fb503e0-715b-47e8-adfd-ad4b7770f73b&grant_type=password&username=${username}&password=${password}`);
and you should be all good.
tonesto7
tonesto7
Anthony
I just keep finding new ideas. Basically, I can share an iOS shortcut that you can add to your device to basically dictate commands to the widget. This means Siri voice commands. And they can be as advanced as we want.
hey Siri , ford widget start my truck
WillB17
Will
2021 F-150 Lariat Powerboost
If you figure out how to do this please let us know, would like to have my more secure password back! Even though I accidentally leaked it to @Sapphire :LOL:
tonesto7
tonesto7
Anthony
V1.2.1 Release
  • Refactored the entire authentication mechanism to get the newer token required for advanced commands and API data calls.
  • Added support for advanced commands like SecuriAlert, and likely any future commands.
  • Fixes for passwords with special characters (hopefully)
  • Updated menu navigation labels and menus so that you can go back to previous menus instead of exiting each time.
  • Added a debug menu under the widget settings menu. It will allow you to save all vehicle data to your device clipboard for easy sharing with me or others.
  • Added an OTA API page under the debug menu as well. (it's just the output in JSON)
  • Added a Vehicle Data page under the debug menu as well.
  • Fixed the way that door status is captured and hopefully fixes errors and will accommodate 2-door vehicles better.
  • Lots of other little fixes.
https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
tonesto7
tonesto7
Anthony
I made a last-minute push and added a vehicle data output to the debug page. So please update if again if you wish to see it.
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
@tonesto7 ... I just want to say "THANK YOU!" for all your hard work on this.
To the rest of us who are reaping the rewards of his work... might I point out that there is a "Donate" button on the Github page for the project:
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 1639631477888
We could at least send him enough to take his wife out for a second anniversary dinner!
Just a thought.
WillB17
Will
Few small things! Tested this on the IPad Pro 12.9” for fun, but in the Medium(?) sized widget, part of the text gets cut off, however the largest widget will show all info without anything being sliced off. Also, my TPMS sensors are not in this set of wheels and is disabled from alerting me on my screen and FordPass via forscan and the truck currently reads dashes (-) on all 4 corners however the widget is reporting a value still.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) FB046E05-3E71-48E4-A38E-7724AF316089
tonesto7
tonesto7
Anthony
It's a glitch in the widget itself. I have the same iPad and it eventually lines up correctly.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) 1639688883865
That's from my iPad Pro 12.9"
No need to use the large widget.
As far as the tire pressure I can only go on what fordpass API shows
Pepito113
Eloy
2021 Ford F-150
Very interesting. Going to read this again
