BHunted1
- First Name
- John
- Mar 17, 2021
- Sumner County TN
- 2021 Ford-150 Platinum Hybrid
- Occupation
- Retired
Worked great! Thanks!I'm looking for a few of you to test this out, please!
Ford Widget Tool Installer (tonesto7.github.io)
So the premise here is that I can't directly update a running script I need another script.
So I created the FordWidgetTool (It's based on scriptdudes installer).
You will go to the website which will hold your hand through installing the installer for the widget tool.
Once the tool is installed it automatically runs and it either installs the Fordpass Widget or updates the existing code.
It will walk you through the steps of installing a helper script that installs and updates the main widget script.
Once this tool is installed that's it, just tap it anytime I announce an upgrade and it just downloads it.
The only time I may require you to reinstall the tool is if there is a required update for the tool's new features. Either way, you will never have to copy and paste-like you did before.
I even recorded a couple of videos of the install process and set up for new users.
