that’s crazy. The IR for blue cruise is emitting constantly? Anyway here are the wires involved.I disabled mine for that exact reason.
The dimming mirrors are self contained and not controlled by the module, so there is nothing in forscan to adjust. The rear view mirror has a front and rear light sensor. The rear view controls the side mirror. Another member reported that the IR sensors used for Blue Cruise appeared to be the cause of it going full dark and staying there. At some point I plan to test a small piece of IR blocking tint over the rear light sensor to see if that makes it operate correctly. I have tinted windows so just having it disabled has worked out fine thus far.
To disable, just disconnect the plug on the back of the rear view mirror. You can partially reinsert the plug, not enough to snap in and make an electrical connection, and avoid any loose hanging wires.
Those sensors are defiantly active all of the time. You can catch them with your phone camera.that’s crazy. The IR for blue cruise is emitting constantly? Anyway here are the wires involved.
I wouldn’t sweat it. I’d wager those are DTCs that occurred when you had the level installed or (did it yourself?). The acm DTCs are the aftermarket audio. Those DTCs are logged to help troubleshoot. That is why Livnitup said to clear them and see if they return. If they return, then you have an issue. I doubt the dealer worked any magic, they probably reset a few modules and cleared the codes.Got truck back from dealer this afternoon. Gear box module fixed. Wrench light successfully off of dash and ford app. Dealer also did recall on underneath heat shield. Glad it was all under warranty. Don’t know if I’m going to try forscan again… nervous to jump back in and begin from scratch, even for a simple Bambi mode or disable double honk. Still afraid that is what caused the malfunction / reduced power wrench light to come up in first place…. Any suggestions , comments?
I had level and tires installed from a local mechanic shop that does them fairly often. You may be correct, however it was just ironic how the wrench light came on the same night I first ever tried FORScan. Totally possible I somehow messed up, but I took it very slowly and carefully... At any rate. It seems fixed, and I'm happy again. I could not clear the light myself, even after resetting every single module to original, clearing DTCs, and going for a drive, etc. So whatever they did, has worked... for now.I wouldn’t sweat it. I’d wager those are DTCs that occurred when you had the level installed or (did it yourself?). The acm DTCs are the aftermarket audio. Those DTCs are logged to help troubleshoot. That is why Livnitup said to clear them and see if they return. If they return, then you have an issue. I doubt the dealer worked any magic, they probably reset a few modules and cleared the codes.
No don’t worry about the open circuit. What happens is that the truck expects to see resistance on a speaker output but it doesn’t. The wires are now going to an amp that has little to no resistance vs the factory speaker so the system thinks there is an open circuit. They didn’t do anything wrong.I had level and tires installed from a local mechanic shop that does them fairly often. You may be correct, however it was just ironic how the wrench light came on the same night I first ever tried FORScan. Totally possible I somehow messed up, but I took it very slowly and carefully... At any rate. It seems fixed, and I'm happy again. I could not clear the light myself, even after resetting every single module to original, clearing DTCs, and going for a drive, etc. So whatever they did, has worked... for now.
When resetting the dtcs and going for the drive, then plugging back into forscan - the audio dtcs did clear. I haven't checked since then to see if they are still cleared. My question is - what is the "issue" if the audio dtcs do come back? Why is this an issue, or why should I be concerned about this? The aftermarket radio company that installed it did a great job - and I'm not sure how you would more so properly, professionally tie this in without throwing a "open circuit" ??
I have a long drive tomorrow to NY, about 850 miles. Then coming back from NY - Curious to see if this light pops back up at any point on this trip. The light didn't come up on trip home from the dealer, about a 30 min drive, which is a starting point after reading on other forums that people have left the dealer only for the light to return almost 15 min or less afterwards. I will update later on my status.
Ok yes, that's what I thought too, and agree with you. I will most likely give forscan another shot after my trip. When doing so - I'm going to plug in and see if any dtcs come up at all. Super curious. Wonder what the front sensor blocked was all about. @Livnitup had mentioned that wasn't normal run of the mill dtcs - at least, I believe this is the one he was referring to not be normal, along with the body control module (?)No don’t worry about the open circuit. What happens is that the truck expects to see resistance on a speaker output but it doesn’t. The wires are now going to an amp that has little to no resistance vs the factory speaker so the system thinks there is an open circuit. They didn’t do anything wrong.
Kinda off topic, but do BOTH of your side-mirrors auto dim? Because only my passenger side does. My driver does not.Those sensors are defiantly active all of the time. You can catch them with your phone camera.
To be fair I have not personally tested the connection between the sensors and the crappy operation of the auto dimming mirror. It was claimed that taping over the IR sensor resulted in the mirrors operating more as you would expect and properly varying the amount of “dimming”. Obviously taping over the sensor is not a viable long term option if you want to use blue cruise. I would like to try some IR blocking film on the mirrors sensor whenever I get around to it.
Only one but it should be just the drivers side. The wiring diagram shows only the LH as well. That is curious if you have a dimming passenger mirror.Kinda off topic, but do BOTH of your side-mirrors auto dim? Because only my passenger side does. My driver does not.
I thought the same thing lol. Is it right hand drive? lolOnly one but it should be just the drivers side. The wiring diagram shows only the LH as well. That is curious if you have a dimming passenger mirror.
https://ultrabrightlightz.com/products/z-flash-bcm-plugin-flasher-for-fordCan someone explain the wigwag line in forscan? What is it for? Can the DLRs be strobed?
Any luck finding the HVAC recycle air timer ? This is something I am dying for to get fixed. It just deactivates automatically minutes after setting itI definitely think the fix for that is in the HVAC module. I just need to take the time to do some experimentation.
I haven’t tested yet, but I think the most likely cause of this issue is “Enhanced Windshield Anti Fogging Strategy”. Ford has a SSM specifically addressing it, effectively saying your HVAC is not broken when it does what it wants vs. what you want, it’s this ”feature” and it’s normal.Any luck finding the HVAC recycle air timer ? This is something I am dying for to get fixed. It just deactivates automatically minutes after setting it
