Power-Up 2.3.0 OTA rolling out
Orlando150
Orlando, FL
Ford
So I actually think that's on Apple this time. I'm still stuck on the dreaded 1.7.1 (despite having the usb stick in for 4 days and counting now) and I have the black border as well on the older version of Sync
Yeah I've seen borders and no borders at various times and various versions of Sync and iOS. It doesn't bother me too much since it's just a pixel or two.
What does bother me are the rounded corners. Not sure who is responsible for that though. Apple might just be sending a black background assuming that it would look normal on 99% of cars.
LHoffmanjr22
Larry
2024 Ford F150 Lightning Flash
Anyone noticed the CarPlay screen is messed up ? It seems they shrunk the the resolution, exposing a black rectangle behind it. Also the Phone List at the top left is misaligned:
IMHO, It looked better in previous versions of APIM
Mine has always been like that. CarPlay itself always had that thin black like all the way around it.
iceman77
Pete
2022 Ford F-150 Platinum
Can you post a screenshot so I can compare ? Also, what version of sync are you running ?
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Well, I’ve started the formal complaint process and issued a demand to @Ford Motor Company Canada to have all modules updated and/or replaced by 2022-02-10, including BlueCruise.
On 2022-02-11 I go to the BBB and make my complaints public.
if that doesn’t work, by March it will be civil action.
along with the broken OTA system, BlueCruise delays, I’m also fighting the frozen door latch and spent an hour idling the truck and fighting with it only to have to ratchet strap it closed and drive to the dealer in -15C temps today. I’m well and truly fed up with getting screwed by Ford.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
SpeedracerCJR- I am in the dreaded 1.7.1 boat as well. I am still trying to get that update too.
I reset everything this morning and have the truck running as we speak. Been about an hour so far. I will let you know if anything happens but I have received no messages on the screen about "DO NOT REMOVE USB" so I'll keep you posted.
Appreciate it, she's been running for 3 hours now, no prompts that I can see. I got a full 36 gallon tank and alot of patience, we'll see which one runs out first.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
What's so strange is that if we purchased 10 pc's of the same make/model, and then proceeded to prepare all 10 for deployment, we would almost guaranteed have identical out-of-the-box experiences, including getting them all updated to the latest build/updates.
Yet with our trucks, I can stick the USB stick in with the truck running and it will only take seconds to recognize what is on the stick and initiate the update.
The next truck will act like nothing has happened.
Then my truck will get stuck in the "restart to finish" loop, only to instantly overcome the loop by me REMOVING the stick against instructions.
While the next truck doesn't get stuck in the restart loop.
The inconsistencies doesn't make sense in the normal ones & zeros digital realm.
But I do admit it makes for some adventure for those determined to do this themselves
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Ok question for the successful getting over the hump, when you formatted the USB stick did you find that a quick format or a long format with ExFAT as the type made a difference? What about the volume label, I've left it blank.
It's been running for 4 hours with nothing and I'm wondering if it's the USB stick now
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
I tried both ways. No difference. Ya can name it whatever you want.
Snakebitten
Coastal Texas
I tried to overcome the restart-loop by formatting the stick the slow way. Made no difference.
And I tried 3 different brands of sticks all quick formatted WITH label "APIM" and they all initiated the update within seconds of inserting the stick.
Sync would show at the upper left hand corner recognition of "APIM" (label) and then "indexing APIM" (again the label), and then in just a few seconds "Updating"
Again, the inconsistencies between how our same Job1 trucks is strange.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
If you used FDRS to create the flash drive, it might be worth starting over at this point by erasing the drive, reformatting it and then performing the APIM update procedure from scratch. My first attempt to update the APIM failed the post-install validation. I started over and it went through fine the second time.
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
JEB this in reference to the 1.7.1 update that seems to be an issue. After this one your correct in following the FDRS but this one update seems to be a pain to kick off.
I've tried 3 different sticks and multiple times with FDRS for some reason this update is stubborn.
JEB
Northern Illinois
You are correct, of course. But a second try with FDRS might rule out some failure points. Besides, even if successful, you have to go back into FDRS anyway to validate the install. So, it’s not like you can just download a flash drive and be done with it. There’s still a post-install procedure to complete.
TJSparky
WA
So Snake your saying you labelled it as APIM and it started the update right away? Or just the USB indexing message? I see that happen with every try inserting the USB sticks. Did you get the message pop-up stating "DO NOT REMOVE USB?"
Snakebitten
Coastal Texas
I think that whatever word you use as a label when formatting you WILL see that label on the Sync screen twice. Once upon recognition it is there, and once for indexing. It does not show the label when indicating the update has began.
But I admit that the first time Sync said "Indexing APIM", for a second I thought huh? Lol
iceman77
Pete
I don't think this is necessary. If your update does not kick in within minutes after starting the truck, chances are it wont kick in at all. The problem is, your APIM (and GWM) is stuck in the middle of installing 1.7.1 OTA (which obviously failed). You need to get those two out of this stuck loop. I have performed numerous master resets on the APIM, disconnected the battery, to shut down the TCU/GWM. Not sure if this helped, but after torturing my truck for a while by numerous APIM master resets and GWM resets I noticed that my Update Screen is not greyed out anymore. And if I recall correctly, that's when I had my USB update kick in! Within a minute of starting the truck! Hope this helps.
