Jesse-Infotainment
2024 F150 Lightning Flash
So far, I haven’t noticed anything obviously missing. I’m wondering if the PMI restored what the update failed to load and now the IPC software is kind of a Frankenstein’s monster of two different builds—the original and the update. In any event, three things I have observed: (1) FORscan seems to be reporting valid numbers for all files; (2) I have all my gauges and menus (as far as I know); and (3) to my surprise, I did not lose any of the FORscan changes to the IPC I made last month to display digital engine and transmission temps. I expected those to be overwritten with new IPC software. That seems to suggest an incomplete installation. FDRS as of Thursday, however, was reporting that the IPC software was up to date. So, I don’t know where I’m at now.
That is what I am thinking.. it’s more of a mash up of files .. if you can in Forscan see how many lines you have for your as build.. should be 14 now 11 before.
When I get home I’ll pull your car and look at what is reported and see if in fact it all updated or not
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
@Jesse-Infotainment below is my IPC info, F113 (Assembly) is off. Any concern with that?
<NODEID>
720
<F110>DSML3T-1A292-CCE</F110>
<F111>ML3T-14F094-CAB</F111>
<F113>ML3 T-10849-CCM</F113>
<F120>MU5T-10F906-FDA</F120>
<F17F>1PB11BFK</F17F>
<F188>MU5T-10F906-FCA</F188>
<F18C>MCCP036872</F18C>
</NODEID>
Jesse-Infotainment
<NODEID>
720
</NODEID>
Those look like 5.0 cluster files? Is that what you have
Jesse-Infotainment
Ok . So yes. What happened to you is what I believe is happening to everyone. It loaded the as build portion and failed everything else. To put into per this update should have taken hours.
Here is my current files on a V8 not updated !
Now his is ideal for comp sake.
Make of this what you want but three files should have been updated .!
Ford F-150 Lightning ECU module programming guide using FDRS 8BFB1C27-2438-449E-AA77-7E35286192A4
Jesse-Infotainment
If you can look in your usb and see what files are on it those are the files that should be in your cluster
Bob_Mac
Bob
North Carolina
I only have 1 file on the USB; MU5T-10F906-FDA.VBF which is what F120 should be and is based on what I posted above.
Jesse-Infotainment
Should have been three
Jesse-Infotainment
Yeah. That was what everyone was getting.. I’ll try to do a v8 update tomorrow and see what I get.
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
While in the toolbox click the All tab then click on TDM on the left side you should see a new tab show with TRM as it's label now click on TRM - Programmable Module Installation (PMI) then Download and run. Go through the prompts as if you already installed a new module and report back if that cleared your DTC
The GSM will not go away... disregard it as it appears to be a bug
OK @Bob_Mac , Downloaded and Ran the PMI, still shows DTC
Should I download and run the others?
Ford F-150 Lightning ECU module programming guide using FDRS 1645985084877
Jesse-Infotainment
Trm will have a dtc there is even a tsb about it.
