jordandev
you could check 1FTFW1E84MKE02174 as I am in the exact same state as Ebrou? ?Can you send me your VIN so I can check something?
Vin sent via PMCan you send me your VIN so I can check something?
Here’s mine: 1FTFW1E8XMFA20546Can you send me your VIN so I can check something?
I already told you what your problem is. Ill leave it alone thoughHere’s mine: 1FTFW1E8XMFA20546
Here are the modules in IPC:You have the same issue as the others with the update not completing.
Need to see what your files are. do a network scan go to IPC see what files are actually loaded.
When you go to FDRS and it shows the list of modules select the IPC and scroll down and show what the files are.
Yeap exactly what I said.. Notice 188 that is wrong. That will need to be corrected before you can move any further. I can correct it. Once its corrected all updates will proceed. Ill have to remote in through teamviewer. When I do Ill need you to be hooked up to the truck same as you would be for FDRS.Here are the modules in IPC:![]()
Ok. I dont, but I am planning on grabbing one. I'll do that now.Yeap exactly what I said.. Notice 188 that is wrong. That will need to be corrected before you can move any further. I can correct it. Once its corrected all updates will proceed. Ill have to remote in through teamviewer. When I do Ill need you to be hooked up to the truck same as you would be for FDRS.
Do you have an active Forscan License?
You cant buy them anymore. You can get a free one though. Once you have one let me know. Message me take about 10 mins to fix if you cant get one I can install one and release it I have in for situations to help peopleOk. I dont, but I am planning on grabbing one. I'll do that now.
Perfect. Quick question. Will the Mongoose work with Forscan or do i need to switch to the other adapter that I bought for it?You cant buy them anymore. You can get a free one though. Once you have one let me know. Message me take about 10 mins to fix if you cant get one I can install one and release it I have in for situations to help people
Mongoose works finePerfect. Quick question. Will the Mongoose work with Forscan or do i need to switch to the other adapter that I bought for it?
Yea, what gets lost sometimes in the mad chase for updating features like Bluecruise is that a few of those updates are Ford's revisions on the drivetrain, especially the Powerboost being brand new out of the box.Just took a 250 mile trip and the Truck is running way better after being fully updated, before updates I was getting around 20-21mpg on the highway in eco, now I am getting 23.5-25mpg.
Makes sense, I’m fairly familiar with engine tuning and it’s complex on its own. Throw EV motors into the ICE mix and it gets even more complex. A whole new set of variables to control for charging and discharge state in idle, acceleration, cruise, deceleration… all in various drive modes. Makes for a lot of room to polish.Yea, what gets lost sometimes in the mad chase for updating features like Bluecruise is that a few of those updates are Ford's revisions on the drivetrain, especially the Powerboost being brand new out of the box.
They might not fix a factory defective component, like a bad torque converter or underfilled transmission fluid, but if your truck is healthy you should find it more refined?
I too am experiencing after putting a couple of hundred miles on it that it just feels more polished.
