adoublee
Makes me sad you will have 80A capacity right there and never be able to access with your Lightning. I think I'd only prioritize charging both at the same time if both vehicles daily commute is more than around a third of their range, which might be your situation. Either way, I don't hold it against youHere is the setup we currently have. Already has wiring for 100A run from our panel. Plan is to swap the disconnect for a sub panel and add the FCSP set at 40A in parallel with the existing EVSE so the wife and I can charge at the same time.![]()
![Grinning face :grinning: 😀](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f600.png)
