Problem with linking Ford Pro charger to Ford Pass
CTBob
Bob
Connecticut
2022 Lightning
Have the Ford pro charger installed and running. However when I try to link it to Ford Pass, when I get to where the charger Network SWA32KCM appears in my wifi networks and it asks me for a password any password I try fails? Ideas?? Ford has been no help. Also has anyone received their 250 bonus kilowatts from Ford? Thanks
Fast911
Tim
San Mateo,Ca
Silverado sold
I was looking through the installation instructions and saw the charger station ID SWA_ _ _ _ _
followed by a Mac address
then a access code.
It‘s on the first page on the installation manual. Try entering the access code when your wifi network ask for the password.
Fast911
Tim
San Mateo,Ca
Silverado sold
Ford F-150 Lightning Problem with linking Ford Pro charger to Ford Pass 362C5F5C-3929-4628-A89F-7D9615CCB800
bg226
Bryan
Anaheim
I got mine to connect using the password on the manual. It wasn't very intuitive and didn't happen right away. I went through all the steps but it didn't say it was connected or give me any indication that it worked. I just closed out of everything and the next time I opened up the app, it showed it connected.
CTBob
Bob
Connecticut
2022 Lightning
then a access code.
I did and it did not work.
CTBob
Bob
Connecticut
2022 Lightning
Has anyone actually fund a true password rather than a sicker with an access code when they removed the faceplate on the Pro charger? I can't get by the password to link the charger.
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
I don't even see the Charger SSID on my iphone. Did you do anything to get that to show up?
Carminus
Paul
NJ
2022 F150 Lightning Lariat
The password is the wifi password. They use the same password for both wifi and "password". The sticker was on the charger and the paperwork/manual.
If your KW show as 0 try rebooting it from the panel also the KW may show up after you unplug it.
I also had to use an older version apk 4.16 since 4.17 ford pass app is broken on Samsung Galaxy S20.
Ford F-150 Lightning Problem with linking Ford Pro charger to Ford Pass Screenshot_20220712-183142_Charge Station Pro
Carminus
Paul
NJ
To see the charger info
Tap account (top right corner picture of head) --> charge station here you can see charger stats.
Ford F-150 Lightning Problem with linking Ford Pro charger to Ford Pass Screenshot_20220712-184606_FordPass
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
There's also a sticker on the front of the installation guide. The booklet that has a picture of the charger on it and says FORD INSTALLATION GUIDE in lower left. They put a sticker there also.
It's hit/miss setting this up. mine gave me issues and i kept bouncing back/forth to get it to work. Finelly after a bunch of trying/leaving the app it syncd. NOT that it does anything for me, so it was a complete waste of time to sync it up, but it's in there now.
Carminus
Paul
NJ
I noticed while the app was searching for wifi signal all local access points were weak even when I had a hotspot near it. My phone had full bars.
Paulightning
Paul
1993 Cobra, 1995 Bronco, 2022 Lightning Lariat ER
Mine won't add the charger in Fordpass. Once I get it connected in the setup App and it wants to move over to Fordpass, it says "ChargePoint not Found" when I hit Next in the "Add your station in Fordpass" section that shows your station ID and password.
FlasherZ
St. Louis Metro
Same for me. And if you try it too much you get put in the penalty box for 15 mins. :)
parabellum85
Austin
2022 F150 Lightning
Getting same error "ChargePoint not Found" when trying to add to fordpass.
CTBob
Bob
Connecticut
2022 Lightning
I still can’t sync my charger to FordPass. Hope when they resolve the overheating issue they will address the password as well.
