vandy1981
I've started playing around with module configuration in our Lariat ER using FORscan and didn't see any dedicated threads for this subject. It would be nice to have a centralized place to share troubleshooting tips. The public version of FORscan doesn't work with BEVs, so you need to email the support team and they may choose to share a BEV-enabled beta version with you. Unsurprisingly, there's a lot of module overlap between the ICE F150 and the Lightning so you can get a good idea of how to enable settings via this thread from FORScan guru @Livnitup. I've tried the following setting changes. MAKE SURE YOU BACK UP YOUR ASBUILT DATA BEFORE MAKING CHANGES. SOME CHANGES WILL BE UPLOADED TO THE MOTORCRAFT SERVICES ASBUILT SITE AND YOU WILL NOT BE ABLE TO RECOVER THE ORIGINAL SETTINGS. ALSO BACKUP YOUR FORScan SETTINGS REGULARLY.
Global window open/close using keyfob: successful in Lariat ER with 5/5/22 build date, but it only works on the front windows because one-touch is not enabled in the back windows.
Propulsion sound: in progress, so far unsuccessful. I was able to make the button show up on the drive mode page by changing the APIM coding at 7D0-09-05, but it only stays on for a second before switching off. I don't notice any difference in motor sound for the brief moment it stays on. I assume that there is another setting in the ACM that needs to be changed to enable it. I guess it's possible that there is some hardware that is missing in non-Platinum trims but that seems less likely.
Glare-free (matrix) headlights (localized dimming of brights based on surrounding traffic): Successful Lariat ER with 5/5/22 build date. The necessary hardware is available in my Lariat ER trim. The swiveling (dynamic bending) lights continue to work with these settings. Settings were adapted from this F150gen14 ICE forum thread. Also thanks to @FlasherZ and
Motor/battery numerical temperature: not successful, may not be possible. The ICE trucks let you surface numerical values for the coolant and transmission temperatures and I'm assuming there's something similar for the Lightning.
Lincoln Folding Mirrors Setting (folds when locked--only unfolds when ignition started): successful in Lariat ER with 5/5/22 build date.
Disable Seatbelt Reminder: successful in Lariat ER with 5/5/22 build date.
DRL/Lightbar Brightness Adjustment (From @jredondox)
BCM 726-42-01 x2x2 xxxx xxxx
BCM (this setting adjusts brightness) 726-38-01 xxxx 64xx xxxx
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
Change Number of Blinks in Turn Indicator (From @jredondox)
724-01-01 XXXX-8CXX XX for 3 clicks
724-01-01 XXXX-94XX XX for 5 clicks
724-01-01 XXXX-98XX XX for 6 clicks
Please post if you've found any other settings that work with the Lightning.
DDM | 740-06-02 | xxxx | xxxx | 01-- |
PDM | 741-06-02 | xxxx | xxxx | 01-- |
DDM | 740-06-03 | 01xx | xxxx | xx-- |
PDM | 741-06-03 | 01xx | xxxx | xx-- |
BCM | 726-11-02 | xx01 | xx01 | xx-- |
BCM | 726-22-01 | xxxx | xxxx | 01-- |
BCM | 726-22-02 | xxxx | xxxx | 01-- |
APIM | 7D0-09-01 | xxxx | xExx | xx-- |
APIM | 7D0-09-05 | xxCx | xxxx | xx-- |
changing 727-01-01 to "xxxx xxxx 0x--" does not enable propulsion sound.
APIM | 7D0-09-01 | x1xx | xxxx | xx-- |
APIM | 7D0-09-03 | xxCx | xxxx | xx-- |
IPMA | 706-01-01 | xxxx | xxx9 | xx-- |
SCCM | 724-04-01 | xxx4 | xxxx | xx-- |
HCM | 734-01-02 | xxxx | x2xx | xx- |
HCM | 734-03-02 | xxxx | xxx1 | x1-- |
HCM | 734-11-01 | 0735 | 89 | |
IPC | 720-01-01 | xx8x | xxxx | xx-- |
IPC | 720-10-01 | xxxx | xxx3 | xx-- |
Changing 720-07-01 to "xxxx xxE5 xx--" or "xxxx xxA5 xx--" doesn't enable numerical temperature display
Disable double honk with exit of running vehicle: successful in Lariat ER with 5/5/22 build date.BCM | 726-63-02 | xxx0 | xxxx | xx-- |
DDM | 740-03-16 | xxxx | xxxx | 01-- |
PDM | 741-03-16 | xxxx | xxxx | 01-- |
IPC | 720-01-01 | xxxx | xx0x | xx-- |
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
