greenne
- First Name
- Nathan
- Jul 13, 2021
- Niskayuna, NY
- 2022 Lightning (Ordered 6/19, delivered 10/28/22)
I liked the Volt tbh (test drove one)..but the whole economy car sales pitch didn't work *if* you used the car for road trips.(Hybrids like the Prius got better fuel economy). If you never needed if for longer trips, then it was silly to haul around a gas engine just to sit there.The Volt was actually pretty good. Gen 1 was rated at 39 miles EV, then a little over 40mpg. 40mpg is not great compared to a Prius, but we didn't need to use the ice often. At highway speed it would actually link the engine to the wheels for a little bit more efficient travel. The big gripe about the car was how loud the engine was and it was not at all tied to vehicle speed. I believe the second generation was quieter, more efficient and had a slightly larger engine. Volt gen 1 also had poor headlights and massive A pillars. I liked the drivetrain overall and eventually replaced it with a Bolt. We developed gas anxiety (what do we need to do to not have the gas engine turn on). I liked having the ice for long drives, but with a 15 mile round trip commute even when below zero I had plenty of EV range. At 14F the engine would turn on for a minute or two, then every few minutes it would turn on again. Never actually warmed up, to oil looked like a chocolate milkshake (probably fuel dilution, but definitely condensation from cold start after cold start). If they made the drive train with 50 percent more power it would have been great in an equinox/terrain.
A range extender for an EV truck, if small, would need to run selectively from a relatively high state of charge so that the battery level could be maintained for as long as possible. It would probably vibrate a bunch, be loud and not very efficient. A true phev version of the truck with a decent size engine (could be NA 4 cylinder) could probably work if there is a large enough battery buffer at the bottom. It would take away from the frunk utility... probably great for towing, but the everyday shorter range utility would be reduced.
So it tried to do two different things and didn't do either as efficient as alternatives...
