Home Charging Speeds
Blaster
VT
F-150L PRO, VW ID.4
Wanted to start a thread for home charging speeds with details on chargers and cables to see if there is any consistency:
1. ChargePoint CPH50, 14-50 NEMA
2. 9.2 - 9.3kw/hour
Curious how other chargers are doing compared to this unit, especially the 80A units.
Roy2001
Sacramento, CA
Tesla MX LR; Prius Prime
220v x 48A = 10.56kW, so the truck get 10.5kWh per hour.
For mobile charger with 32A, 220v x 32A = 7kW, the truck get 7kWh per hour.
Assume ER battery charge from 20-80%, it needs 80kWh. So charge time is 8 hours with a 48A charger, 12 hours with mobile charger.
duncanmaio
Duncan
Norwood, MA
I don't know that you have to call Chargepoint, but I think you need to start the configuration over from the beginning to select a different amperage - if Chargepoint can do that remotely, that might be easier (although the setup was pretty fast and simple, if I recall correctly).
Hard wiring might require new (larger) wire, and a disconnect depending on the jurisdiction.
yed19
Jay
Washington
'22 F-150 Lightning Lariat, 2012 RR Sport HSE
Someone can check my math... but... 80amp*220 V = 17.6KWh theoretical maximum for FCSP. 131*55% (80%-25%)= 72KW. 72KW/17.6KWh = 4.09hrs.
I.e. You can charge your truck from 25% to 80% in 4.09 hrs with FCSP. Theoretically
However, The charge rate is not that high, so would the curve really be affected after 80%? I get that it changes with the DC fast charging, but since the rate is only a max of 17.6, does it really matter?
Even during initial configuration, you have to call ChargePoint. If you don’t, it defaults to the minimum of 16A.
Ford F-150 Lightning Home Charging Speeds 9482F5CC-3355-406A-8DC1-2F8E5F36ACEF
Blaster
Blaster
VT
F-150L PRO, VW ID.4
Just checked with charge point, I am set to 48A, to take advantage of the 60A circuit we would need to hardwire the charger.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
I now charge with FCSP when temps are below mid 70’s. I can set max amps at 80 but past measurements show around 77-78 amps. If I have to charge during the day I’ll drop max to 60. No cycling then but I haven’t measured actual amps (too lazy to back out 9 machine bolts in charger case).
The charge times seem to match up with 220X80 watts between 20% and 80% SoC, my normal range.
FlasherZ
St. Louis Metro
The mobile charger will do only 30A. For whatever reason, it's rated at 32A but only advertises 30A to the truck.
Also, most people will have closer to 240V - some older grids in the northeast, in particular, still use 220V. Because I'm close to the substation that serves a lot of rural homes, I get between 245-248V usually. So most people will use 240v * amps to get the watts.
FlasherZ
St. Louis Metro
The FCSP doesn't advertise a 96% duty cycle to the truck, only 94.5%, which translates to 76-78 amps. It seems all Siemens chargers sit on the conservative side of things.
duncanmaio
Duncan
Norwood, MA
That was not my experience - the Quick Start Guide has instructions to connect to the unit via wifi and you get one shot at setting amperage. If you don't configure it, it stays at 16 amps. After configuration, there is no way to go back and change amperage.
